66 Bronco rebuild
#31
here is some more. no need to be jealous, you been driving yours past 3 yrs. I been working on mine. Its been so long since ive driven mine I forgot how much fun it is, I just remember for some reason Ive got to get it done so I can drive it again
Looks awesome there casey
Dammmmnnnn!!!!! That is nice!:xyxthumbs: I dig the silver frame/ silver body combination.
and shaved door handles... slick!
Thanks evrybody, and think you are joking bout the shaved door handles or atleast i hope you are. Now its just a matter of getting it put together. I also have a cage that still needs to be welded together, painted, and installed.
Also got to figure out some bump stops so as not to eat up those tires and fenders(was think bout doing something like the mud trucks) and some type of sway bar setup(probably also like mud trucks)
Its strickly going to be a driver for a while then those fenders will most likely get cut.
I was joking.. But I did have to look twice! Next time I come down there to hunt ill let you know so I can come see it.
That would be great sc74. If I remember right, you said you had family over round 310 and 45. Thats very close as in no more than 3 or 4 miles maybe.
Right now im battling lining up the doors. I had them close to right before I disassembled it for paint. Back edge of pass side door is jacked above the bed. Ive already put a shim under front body mount(1/8" wasnt enough). Imconsidering shaving the pass side floor mount to see if that will work. Any suggestions are welcome.
I think it looks Great , can tell you put some time in it...DWB
moving this to the build threads Casey...keep us posted!!!
Here is my new hard top. Still got to get ready for paint.[ATTACH=CONFIG]6591[/ATTACH][ATTACH=CONFIG]6592[/ATTACH][ATTACH=CONFIG]6593[/ATTACH][ATTACH=CONFIG]6594[/ATTACH][ATTACH=CONFIG]6595[/ATTACH]
  Bronco Camo Wraps circlefire 7 3,109 03-27-2018, 05:20 PM
Last Post: circlefire
  68 Bronco wepuckett 126 28,413 04-27-2017, 09:57 AM
  73 Bronco wepuckett 115 24,670 05-17-2015, 11:11 PM
  That storage locker Bronco 66Roadster 53 11,903 01-17-2015, 11:49 AM
  Wheels and Tires. Stock 1996 Bronco 5.8L 4wd or w/ 2" lift and poly body mounts. jrshepherd 2 2,234 05-10-2014, 02:36 PM
Last Post: Wickedlester
  1969 Bronco Build jtoney51 9 3,793 07-09-2013, 10:26 PM
  '77 Bronco 4bt Conversion High Pressure 74 37,387 07-05-2012, 03:14 PM
  my bronco build 66bronco 65 16,334 04-17-2012, 11:54 PM
  Just getting started 74 Bronco N747JB 7 2,697 10-29-2011, 07:59 PM
Last Post: N747JB
  BC Bronco shorty header install with 2-in-2 exhaust Crawdad 14 6,012 01-04-2011, 02:03 PM
