mini buildup
#51
Thanks man
Now just gotta get the new dash in, and the rear axle housing. Then if time allows my new fox 2.0 shocks
I looked at the Fox shocks as an option for the setup on my rear axle. The adjustability would have be awesome but they did not offer something with the measurement range I required. Sad
Yeah I got a pair of 2.0 emulsions with external res. for cheap so we will see
I figure I would update this thread since replacing my clutch turned into another drivetrain rebuild. I got all the old drivetrain out. [Image: ebe7e4ut.jpg]
Now that its all not going back in I decided to change my rear main seal out since it was leaking. [Image: dyme7yru.jpg][Image: qejysyja.jpg]
Ended up not being to bad had to take the drag link and track bar out to drop the pan. I did rip one seal on the first time but I had an extra, put back together with no problems just took a bit of time. Now I'm waiting for the oil pan gasket to come in. It took a couple trips but we firguired out the right one. The block came out of 74 galxiee.
I hope you RTV'd the piss out of that seal.
I offset the seal put rtv on the ends, and sprayed a light coat of copper gasket on the mating surfaces. There was little rtv on the one I took it probbally didn't need to be replaced but I didn't anyway
Upgraded the arb air line to there heavy duty air line. [Image: 3ahy7esa.jpg][Image: eju6a3e5.jpg]
I went ahead an installed a air hose for my compressor [Image: zyzaqaby.jpg]
How far did the atlas shift your drive shafts? Whatcha gonna do with old ones?
Well today I installed a set of 4.5 coils to try out. Also installed a set of hd coil buckets. Now the limiting factor is the shocks[Image: e3f8fdabede08b67eafc67325d7d7a13.jpg][Image: 8c31a050ffa3fb2eec624d8baee49099.jpg]
Shocks are optional. Trash 'em
Users browsing this thread: 78 Guest(s)
