01-28-2014, 02:54 PM
Only one gas can. You should add another just to be safe
01-28-2014, 02:55 PM
Ur a dick
01-30-2014, 08:48 PM
Pulled all 4 tires, removed beadlocks, vacuumed all balancing beads, installed beadlocks, retorqued 200 bolts in 3 increments, installed tires.
They are getting rebalanced tomorrow. Fun factor: -9 ugh! Sent from my GS3 on CyanogenMod with tapatalk2
01-30-2014, 10:56 PM
Guess the balancing beads not work out? How much weight did you have in each tire?
01-30-2014, 11:01 PM
They will go back in. My weights got ripped off over the last few trips and it is too much for beads to compensate. About 8oz in each. I like to initially balance with weights and let beads do the long term dynamic balancing as tires wear.
01-31-2014, 12:07 AM
snipes243 Wrote:Only one gas can. You should add another just to be safe ^^^^^^ oh, and what he said ![]() If you could add a pickup in the bottom of the can and hook it to a fuel selector, that'd be sweet! no need to get out of the truck...
01-31-2014, 08:52 AM
Need i remind you who ran out of gas on the trails during the last work day bart?
Fwiw- i have never run out of gas. It has always been either my system vapor locking or my stupid pickup starving at extreme angles.
I am confident i fixed the vapor lock issue by removing the return line routing through the accumulator. One day i would like to run an in tank pump or the walbro pickups to fix the other half of the problem. Until then, i still run the risk of starvation at extreme angles but i will never run out of gas! Sent from my GS3 on CyanogenMod with tapatalk2
02-03-2014, 05:51 PM
(This post was last modified: 02-03-2014, 05:54 PM by 1st Bronco.)
[ATTACH=CONFIG]7527[/ATTACH] before picture.
[ATTACH=CONFIG]7528[/ATTACH] after picture. Front tow hitch and steering stabilizer installed thanks to a more skillful friend. Next, remove ugly NC4x4 sticker and find some 31 A/T tires..... Hitch is bolted, three #8 on each side, not welded, per CB4x4 instructions.
VIN# makes it a 1985, the engine block# is an 1989, and the front end is from a 1987. I call it Broncenstein. ![]()
02-03-2014, 06:50 PM
very nice, are you planning to build a bumper or use a stocker?
Latest Bronco Driver Cameo | Bronco Biff | 9 | 3,779 |
Bronco sighting in eastern Pendleton SC | Crawdad | 0 | 1,642 |
Bronco new year resolutions | wepuckett | 12 | 3,432 |
Check this bronco out | snipes243 | 5 | 3,806 |
Bronco Christmas | snipes243 | 23 | 5,566 |
Who's Charleston Bronco made my local news? | Bronco Biff | 0 | 1,023 |
Ruff 76 I looked at today. | Broncitis | 20 | 7,098 |
The Bronco made the news today | snipes243 | 8 | 2,557 |
Not a bronco but..... | firefighter2134 | 4 | 1,942 |
