Didn't hurt anything behind the core support. Cosmetic. Caved in the grille. Fixed the marker light bucket but still need the lens. The strip on the hood is the top trim piece for the corral molding. The center of the hood was jacked up about a foot and cracked in the center. Fixed that with braces on the bottom side. The plates backing the hood pin hole cover the splits in the hood at that point. A little heavier but solid again.
[Image: 2rwp56f.png]
Not sure if my fan is big enough
Is that a 14"?
And u seriously don't think it's big enough or ur being sarcastic?
I focused on getting everything off the frame to prep it for media blasting but got stuck on the last to body mounts the bolt is broken off so can't pull the bolt and tap them out. Tried to drill the bolt out but drill bit broke tried to use cut off wheel but too much rubber in the way to get to the sleeve or bolt. Any suggestions would be greatly appreciated.
Torch the rubber first.
chuzie Wrote:And u seriously don't think it's big enough or ur being sarcastic?
Can a fan be to big?
snipes243 Wrote:Can a fan be to big?
Ur drunk.
Nah
  Bronco sighting in eastern Pendleton SC Crawdad 0 1,644 01-15-2017, 10:06 AM
  Bronco new year resolutions wepuckett 12 3,437 01-03-2016, 11:52 AM
  Ruff 76 I looked at today. Broncitis 20 7,105 09-05-2015, 08:49 PM
