08-03-2014, 07:52 PM
Uh, yeah. That.
Aired up the tires, torqued the lug nuts, checked fluids, and went for a Sunday drive!
Uh, yeah. That.
08-03-2014, 07:54 PM
Aired up the tires? Why? Do they go flat that often? :-D
08-03-2014, 08:08 PM
It still rolled. Just a little under inflated. Like a few of us on the board here
08-04-2014, 07:48 PM
Well finally got the final pieces I needed to get the new compressor switched over to 3/8 other then the T at the end as I still need to figure that out. Also picked up some blades for the pnuematic cut off tool and chisel set for air chisel or hammer. Now to get the holes drilled and lines marked to cut out the bad floor pans.
08-04-2014, 08:53 PM
What did I do today? Ugh!
Let's see... Installed full circle snap rings on my front shafts with 760x joints. While replacing spindle bearings, found one of my spindles was bent. Now my perfect alignment is back to square one and am in search of a replacement spindle if anyone has one. Water heater crapped out, fridge crapped out, toilet and shower clogged. Awesome day. Oh and I'm in a plane headed for Charleston so I get to pay someone to fix the household crap. FML!
08-04-2014, 10:59 PM
chuzie Wrote:What did I do today? Ugh!I can help you out with that stuff, just wait till Labor Day weekend and I can fix the toilet and shower drain! Boil some water and pour down shower drain it may loosen ur chit up. You might wanna chk your clean-out bc if its stopped up ain't nothing gonna drain. I can help out with hot water her too if you can wait! ![]()
08-05-2014, 12:32 AM
Chuz, when you stop up the toilet, resorting to the shower is NOT the answer!
08-05-2014, 10:18 AM
Finally got around to working on the Bronco again. New front turn signal buckets/wiring, H4's w/ relay harness installed, new headlight switch, drilled and cut the tunnel cover for the 3spd conversion. Now to fix the t-case shifter. Old mechanism broke and now installing a twin stick.
Still need a welder in/near Hickory, NC for the Family cage.
08-05-2014, 01:53 PM
66Roadster Wrote:Chuz, when you stop up the toilet, resorting to the shower is NOT the answer! Yep. Everyone knows that is what the kitchen sink is for. Insinkerator FTW ![]()
08-05-2014, 01:56 PM
Crap! I wanted the 1000th post. Now I have to wait another 10 years. :eek:
Latest Bronco Driver Cameo | Bronco Biff | 9 | 3,591 |
Bronco sighting in eastern Pendleton SC | Crawdad | 0 | 1,586 |
Bucking Bronco | ParadisePWoffrD | 0 | 941 |
Bronco new year resolutions | wepuckett | 12 | 3,214 |
Check this bronco out | snipes243 | 5 | 3,667 |
Bronco Christmas | snipes243 | 23 | 5,251 |
Who's Charleston Bronco made my local news? | Bronco Biff | 0 | 968 |
Ruff 76 I looked at today. | Broncitis | 20 | 6,789 |
The Bronco made the news today | snipes243 | 8 | 2,433 |
Not a bronco but..... | firefighter2134 | 4 | 1,843 |
