Firestone must love you, that's what 4 alignments at 75 bucks a pop.
8 times on the rack now and they are free after i purchased the lifetime alignment for $150. They must really love how i am getting my money's worth!
chuzie Wrote:Replaced leaking water heater. Lots of fun.
Removed 0.5deg sleeve and installed 1.0deg sleeve on driver side. Appointment for 8am tomorrow @ Firestone. I hope my math is right!
Can you post a pi of this "sleeve" you are installing and where you are installing it? You have lost me, though pretty easy to do.
Crawdad Wrote:Can you post a pi of this "sleeve" you are installing and where you are installing it? You have lost me, though pretty easy to do.
Top 2 are stock 0deg. Bottom is 1.5deg.
[Image: 955972eb32ed31c75482c7e8faa5260a.jpg]
Under the upper ball joint retaining nut is the sleeve and tapered washer.
[Image: 0b729d6ce9e4074e74de5ebcb2caa3d1.jpg]
Ohhhhhhhhhhhh yeah...... (Way over my head)
Crawdad Wrote:Ohhhhhhhhhhhh yeah...... (Way over my head)
It's super simple to do.
Remove wheel.
Remove nut
Tap stud lightly
Use special socket tool to remove stock sleeve
Install reverse of removal.
After new sleeve is threaded, install wheel and put weight on wheels to prevent ball joint spinning.
Don't forget to add tapered washer to keep nut flat.
Go check alignment and dial it in. Take the socket too.
Easy as pie.
I'll know who to call when I have camber issues. I thought it was something the alignment place fixed, not me. Give me about two years, by then you will be a commanding general!
chuzie Wrote:8 times on the rack now and they are free after i purchased the lifetime alignment for $150. They must really love how i am getting my money's worth!
I will have to remember the lifetime alignment deal if they havn't cancelled it after you totally took advantage of it.
wepuckett Wrote:I will have to remember the lifetime alignment deal if they havn't cancelled it after you totally took advantage of it.
I also purchased the lifetime alignment for my Honda in 2006. Maybe used it 3 times. It all evens out in the end.
Hell, if the non-mechanics there wouldn't give me the deer in the headlights look when I explain what I want, I wouldn't be so insistent on doing all the adjustments myself. There is a lack of talent in the automotive repair industry these days.
I think that lack of talent is a little bit of an understatement mostly because of all the computer changes most modern mechanics a computer guys running a computer.
