That storage locker Bronco
#51
Forgot the update here. The Amazin' Blazin Chuck has resurrected this sad Bronco now dubbed, "The Albatross".
Second brand new clutch, (went with diaphragm style this time), new flywheel, third set of rear leaf springs (two change-outs), new lift blocks... am I forgetting anything, Chuck?
Not to mention all the other major things he already did: different transmission, different transfer case, different shifter, different rear axle housing upgraded to big bearing, all new rear brakes, header to muffler stop-leak, new starter.
As Chuck puts it, this Bronco has a lot of potential.
[Image: 10dba3920cd2b83b1b070fff9117bc7a.jpg]
Good job guys! Great to not see this one go back to the storage locker! Don't let Chuzie test drive it.
Ouch!
So it ended up being the Clutch/Flywheel that was causing the bucking? Just curious, is the differential ratio 3.50:1 ? Can't help but think if it was 4.11:1 it would have helped.
  Bronco Camo Wraps circlefire 7 3,725 03-27-2018, 05:20 PM
Last Post: circlefire
  68 Bronco wepuckett 126 34,624 04-27-2017, 09:57 AM
  73 Bronco wepuckett 115 30,295 05-17-2015, 11:11 PM
  Wheels and Tires. Stock 1996 Bronco 5.8L 4wd or w/ 2" lift and poly body mounts. jrshepherd 2 2,566 05-10-2014, 02:36 PM
Last Post: Wickedlester
  1969 Bronco Build jtoney51 9 4,476 07-09-2013, 10:26 PM
  66 Bronco rebuild Casey835 56 15,560 06-04-2013, 07:45 AM
  '77 Bronco 4bt Conversion High Pressure 74 41,408 07-05-2012, 03:14 PM
  my bronco build 66bronco 65 19,637 04-17-2012, 11:54 PM
  Just getting started 74 Bronco N747JB 7 3,190 10-29-2011, 07:59 PM
Last Post: N747JB
  BC Bronco shorty header install with 2-in-2 exhaust Crawdad 14 6,794 01-04-2011, 02:03 PM
