mini buildup
#71
Always mind the "gap." Good work
Looking good. The weather should be cooperative this weekend. Get it done!
chuzie Wrote:Always mind the "gap." Good work
I will mind the "gap"
Time to drill some spot weld hole [Image: daaf34412b1de6d363a0b1b0abdf9fd5.jpg]
[Image: 101509ca8821350b6267bb85e434e18a.jpg] the back angle piece is temporary until I can get some angle bent up
[Image: 91e25e0cdd86ff09156f912aaf78f2a4.jpg]
Coming along nicely!
I'd be tempted to leave that back angle in place and just flush it up against what is there. I know it looks kinda wonky like but you ought to be able to straighten it up well enough.
It would be a good time to remove the pan and cut that bad metal out of the kick panel(s) and put a new patch panel there before welding the floor(s) in.
Also, do realize that you are going to make chuzie jealous with all that wire you've got going on.
I found an idea for a fuse box today that he might like.
Wow! Just frigging wow.
I will give it til tomorrow at the last to see chuzie's new creation
I'm on the road. Maybe when I get back in 3 weeks.
3 weeks so your say the design will be refined to include Tupperware with latches sounds like a great improvement
Actually, this is my next addition. Cherokee relay box.
Users browsing this thread: 67 Guest(s)
