mini buildup
#91
Yeah I bought a replacement that I'm going to weld into.
Got back at it today got the crossmember in, came out not bad at all[Image: 6cdbacd161089ec9e8643d9203836267.jpg][Image: 6e8be000e588b57d231069e4708df0d6.jpg]
Started getting the pan trimmed up this side is looking a ton better [Image: 316899fda7797436fa92ec26c4e562ff.jpg][Image: be4999da30a20eecaf072bf2b69442d6.jpg]
Nice. Sure hope that bolt hole on the cross member lines up right. ;-) good job dude.
What hole are you referring too, hole guru
"hole guru" that's what she said!
First pic just right of center on x-mbr.
Good eye there hole guru but I don't think she would be to happy since that is the rear hole.
The hole won't be used. I ordered a front crossmember and scabed it into the rear crossmember, which was a pain since the channel depth was different.
Got the floor pan fitting great tonight just need to finish the rear angle piece [Image: 427a639618577d457bc2561ae439ce4b.jpg][Image: 75833b065fdc067017cbec35d7812e65.jpg]
finally got the passenger floor welded in tonight [Image: 65177b387e9e218807d1b5fab9352319.jpg][Image: 00722508fd2fe589ef20f2924b51fb67.jpg][Image: e8ddc052bfcff61885f2c1d8ce854dbe.jpg][Image: 4e0199638d43090099243b2761da0fbe.jpg]
Nice welds.
Your signature indicates twin sticked dana 20. FIX IT!
What are you the signature police?
Users browsing this thread: 65 Guest(s)
