Did you get the pink masonry twine? You know so that it will match the skooter....
"Made a synthetic rope repair kit in anticipation of my eminent stupidity. "
That is easy. It is called a knot.
I put the IROK's under the racer and did a non-Chuzie approved maintenance item.
Replaced the rear shackle bushings. The new ones will probably limit my articulation a bit more than the old ones did.
nice...is it really pink??
Middle fingers to all three of you!
Nice bushings. They easily could have lasted another year. :-D
dang bart...maybe you should get the greasable bolts , might have helped?
blazinchuck Wrote:dang bart...maybe you should get the greasable bolts , might have helped?
Chuck's alter ego finally surfaces...
Thought you all would like to see what color rope arrived for me at Chuck's today.
Sorry to disappoint!
That sucks that it's not gonna match your scooter [Image: dd8cd7089022002b141e93f53df59679.jpg][Image: bd6cb8614116cbbe41c3f54cf300aaab.jpg]
That Camo rope will be really easy to lose in the woods. It may get shot thinkin its a very long snake. And lastly you'll have to get a new skooter to match.
I got the transplant buttoned up this evening and after putting the flywheel, clutch and pressure plate on it I will be ready to drop it in. Also got the Steering shaft ext finished and the front brake lines are complete now. Just got to bleed the front now.
Broncitis Wrote:That Camo rope will be really easy to lose in the woods. It may get shot thinkin its a very long snake.
I have that problem a lot when I take a piss in the woods!
All this work on the Bronco and ur not coming to Tellico. Boooooo.
  Bronco new year resolutions wepuckett 12 3,434 01-03-2016, 11:52 AM
  Not a bronco but..... firefighter2134 4 1,943 07-11-2015, 10:10 PM
