04-15-2015, 10:38 PM
Did you get the pink masonry twine? You know so that it will match the skooter....
04-15-2015, 10:45 PM
(This post was last modified: 04-15-2015, 10:49 PM by broncosbybart.)
"Made a synthetic rope repair kit in anticipation of my eminent stupidity. "
That is easy. It is called a knot. I put the IROK's under the racer and did a non-Chuzie approved maintenance item. Replaced the rear shackle bushings. The new ones will probably limit my articulation a bit more than the old ones did.
04-15-2015, 10:48 PM
nice...is it really pink??
04-15-2015, 10:56 PM
Middle fingers to all three of you!
Nice bushings. They easily could have lasted another year. :-D Sent from my GS3 on Cyanogenmod with the older / better version of Tapatalk!
04-15-2015, 11:00 PM
dang bart...maybe you should get the greasable bolts , might have helped?
04-16-2015, 12:55 PM
blazinchuck Wrote:dang bart...maybe you should get the greasable bolts , might have helped? Chuck's alter ego finally surfaces... Sent from my GS3 on Cyanogenmod with the older / better version of Tapatalk!
04-17-2015, 03:55 PM
Thought you all would like to see what color rope arrived for me at Chuck's today.
Sorry to disappoint! Sent from my GS3 on Cyanogenmod with the older / better version of Tapatalk!
04-17-2015, 04:10 PM
That sucks that it's not gonna match your scooter
04-17-2015, 10:53 PM
That Camo rope will be really easy to lose in the woods. It may get shot thinkin its a very long snake. And lastly you'll have to get a new skooter to match.
I got the transplant buttoned up this evening and after putting the flywheel, clutch and pressure plate on it I will be ready to drop it in. Also got the Steering shaft ext finished and the front brake lines are complete now. Just got to bleed the front now.
04-17-2015, 11:07 PM
Broncitis Wrote:That Camo rope will be really easy to lose in the woods. It may get shot thinkin its a very long snake. I have that problem a lot when I take a piss in the woods! All this work on the Bronco and ur not coming to Tellico. Boooooo.
Latest Bronco Driver Cameo | Bronco Biff | 9 | 3,064 |
Bronco sighting in eastern Pendleton SC | Crawdad | 0 | 1,479 |
Bucking Bronco | ParadisePWoffrD | 0 | 847 |
Bronco new year resolutions | wepuckett | 12 | 2,732 |
Check this bronco out | snipes243 | 5 | 3,378 |
Bronco Christmas | snipes243 | 23 | 4,493 |
Who's Charleston Bronco made my local news? | Bronco Biff | 0 | 849 |
Ruff 76 I looked at today. | Broncitis | 20 | 6,083 |
The Bronco made the news today | snipes243 | 8 | 2,072 |
Not a bronco but..... | firefighter2134 | 4 | 1,609 |
