Git er done William. Wanna see that 68 in the woods. Less than 3 months ago mine had froze brakes, a different motor a shot out J shifter, rotten tires, no battery, no rollbar, no front bumper and many many other problems. Looking forward to seeing yours driving and you smiling as you wheel it around.
Replaced the left side exhaust donut. Musta damaged it when a exhaust clamp caught on a rock in the garden. I think i am gonna have to change it over to single exhaust to be able to tuck it all in nice and tight. Speaking of the garden i got the okra and sweet corn planted today also.
Less than 3 months ago my 67 kinda looked like a Bronco. Now, well, er, nevermind...
I had a conversation with EBer the other day and said I shouldn't have to replace my rear mounts since I had the frame galvanized. I wasn't convinced so I purchased some new rear mounts from WH. Wow, am I glad I made that choice!
I just drove it around doing some errands today and went and picked up a nice Victor cutting torch with hoses regulators and a oxygen bottle which is full. Now I need a acetylene tank and a cart. If I need I can burn propane out of a grill tank til i get the acetylene. It came with a propane tip. I figure it was a good deal for 200 bucks. Just the Oxygen tank woulda been that much. I then finished planting the garden with pintos, colored butter beans, purple hulls, Squash, zuchini, and cucmbers. If we get the rain we will eat good.
Believe it or not I have not put a wrench to it in 2 days. I did however chase down some possible future parts. 1 is a 5.0 Fuel Injected full size bronco (not sure of the year til I go look at it tomorrow).
The other is a 88 F 150 Fuel Injected 4.9L 6 cylinder with a 5 speed tranny. If I can talk him down some I will harvest the 5 speed for future use and Bart is interested in the Fuel Injection, all other parts will be available if someone can use any of them. The full size is only 5 miles from the house and I can drive it home. Not sure how many of the parts will be useful in a EB but the motor and Transmiision should be worth the 700 I can buy it for. Stay tuned.
thats pretty cool,the f150 fuel injection does not fit well in a bronco tho...if your looking at going efi, look at explorers...direct swap in. however, if your doing a off road kit in your carb, it will be way better now than last weekend.not sure of many parts you can use from those two trucks tho
The Bronco is a 87 with 116,000 miles on it and a AOD Transmission. Not sure but I do not think it would be a roller motor. Rollers did not begin til what 89 or 90?
Got the new rear shock mounts on today. My welding skills are less desired, not a big fan of welding galvanized steel. Cut off the rubber mounts off too. So much thick rust scale between it and the frame.
Crawdad Wrote:Got the new rear shock mounts on today. My welding skills are less desired, not a big fan of welding galvanized steel. Cut off the rubber mounts off too. So much thick rust scale between it and the frame.
Drink a glass of milk it'll usually get rid of the metallic taste welding Galvanized steel leaves. If you clean the coating off good it welds like mild steel should.
  Latest Bronco Driver Cameo Bronco Biff 9 3,614 05-10-2017, 11:55 PM
  Bronco sighting in eastern Pendleton SC Crawdad 0 1,593 01-15-2017, 10:06 AM
  Bucking Bronco ParadisePWoffrD 0 945 01-18-2016, 12:18 PM
  Bronco new year resolutions wepuckett 12 3,257 01-03-2016, 11:52 AM
  Check this bronco out snipes243 5 3,690 12-29-2015, 08:58 PM
  Bronco Christmas snipes243 23 5,339 12-26-2015, 04:22 PM
  Who's Charleston Bronco made my local news? Bronco Biff 0 974 10-05-2015, 08:58 AM
  Ruff 76 I looked at today. Broncitis 20 6,861 09-05-2015, 08:49 PM
  The Bronco made the news today snipes243 8 2,452 08-24-2015, 12:45 PM
  Not a bronco but..... firefighter2134 4 1,856 07-11-2015, 10:10 PM
