05-30-2015, 04:28 PM
Replaced the idiot light type oil pressure sending unit with a gauge type. Looked a bit closer at what is gonna need to be done and where the shifter will be coming thru the floor when I put the 435 in.
06-01-2015, 09:44 PM
Good. No shove this in your rear end!
http://classicbroncos.com/forums/showthr...p?t=255619 Sent from my GS3 on Cyanogenmod with the older / better version of Tapatalk!
06-01-2015, 11:02 PM
Moved the 435 into the shop and made some room to get started on putting it in and found that something in the shifter or trans is froze up. Guess I will pull the shifter tomorrow and see if I can figure out what in binding it. No side to side and no forward movement.
06-02-2015, 12:56 PM
Broncitis Wrote:Moved the 435 into the shop and made some room to get started on putting it in and found that something in the shifter or trans is froze up. Guess I will pull the shifter tomorrow and see if I can figure out what in binding it. No side to side and no forward movement. Pull the shift collar off, It probably didn't get lined back up right when I had too take it off to remove the trans.
06-02-2015, 05:08 PM
I need to snap a picture this evening for proof and post it up but to get ya guessing I changed the plugs and bolted on a 100 HP to the lil' 289 Sunday finally getting something done that has been sitting around in my garage since the late '80s....(or make that garages because I've moved 1 time too!) ....Dang, meant to snap a shot of the vintage box before it went away with the recycle stuff today!! Take your best guess!!
06-02-2015, 05:32 PM
Cold air intake or alluminum intake?
06-02-2015, 05:46 PM
Paxton Supercharger?
06-02-2015, 05:57 PM
The essence of a thousand kittens mixed with bits of ground unicorn spike?
I pulled the top off the 435 and figured out how to get the shifter timed with the gears and reinstalled it and it shifts now. The small nylon clips (edited/Shift Fork Inserts) for lack of a better name for them which are located on the 1-2 and 3-4 forks are deteriorated so I am gonna see if I can find some to replace them before putting transmission in. On a side note the gears all look perfect with no signs of chipping.
I did ride a lil short local trail this afternoon and idled thru some mud. When it started getting deep I turned around and came out cause I was alone and have not acquired a winch yet. Think I may order a Smittybilt this evening.
06-02-2015, 06:57 PM
Chuck has a smitty he may be looking to sell. Hit him up
Latest Bronco Driver Cameo | Bronco Biff | 9 | 3,591 |
Bronco sighting in eastern Pendleton SC | Crawdad | 0 | 1,586 |
Bucking Bronco | ParadisePWoffrD | 0 | 941 |
Bronco new year resolutions | wepuckett | 12 | 3,213 |
Check this bronco out | snipes243 | 5 | 3,666 |
Bronco Christmas | snipes243 | 23 | 5,251 |
Who's Charleston Bronco made my local news? | Bronco Biff | 0 | 968 |
Ruff 76 I looked at today. | Broncitis | 20 | 6,789 |
The Bronco made the news today | snipes243 | 8 | 2,433 |
Not a bronco but..... | firefighter2134 | 4 | 1,842 |
