Waiting on parts to get here. In the meantime, started surgery on my centech harness to take all the stuff I won't use out of it.
Can't find my key for the ignition though.:banghead:
Found the key today in the attic of surprises. Small victories!
That was pretty much offset by wasting $10 on a serpentine belt. I guesstimated at the size and was off by an inch to the short side. I'm not shipping it back. All the parts houses here don't have them in stock and want about $40 for one.
Almost finished with the centech on a customers. Just need to button up the tail lights. Had to remove a section of wiring between firewall and gas tank...almost two feet
Sent from my HTC6535LVW using Tapatalk
Been battling a nasty misfire issue with my Bronco. it started shortly after I filled up at Sunoco. I immediately thought I got bad gas and flushed my system and cleaned my injectors. Since my fuel system was okay and I had no codes or vacuum leaks, the only possibility was ignition.
My super fancy scan tool software was not offering misfire data and I just assumed it was a function of the PCM rather than the software. I thought hooking up to an engine analyzer was my only option to gather ignition data. Anyway, I ended up dropping $40 to have a local guy plug in his fancy snap-on scanner. It immediately flagged #4 as misfire and once I swapped the plug wires the misfire moved to #3 so I knew it was a bad wire.
I am now better educated regarding the limitations of the scanner software I select and am looking at alternatives that support mode 6 among others.
I am 95% NovRun ready. Just have to install my new ram cylinder.
That sounds pretty neat. Glad you found the problem
Someone please donate a shirt for chuck? This is pathetic!
chuzie Wrote:Been battling a nasty misfire issue with my Bronco. it started shortly after I filled up at Sunoco. I immediately thought I got bad gas and flushed my system and cleaned my injectors. Since my fuel system was okay and I had no codes or vacuum leaks, the only possibility was ignition.
I've been using this scanner on my ODB-II vehicles with good success. It was $80 on sale but has a lot of features. OBDLink MX Bluetooth Scan Tool Part #426101 https://www.scantool.net/
So I got the transmission and transfer case rebuilt. Yhey look great but the big question is do they work. I noticed the radiator was leaking when I was putting in the transmission cooler ( I refuse to admit I did it during the install). Then I saw the power steering pump was leaking so ordered a new HD one with brackets. Didn't like the original alternator so have a 3G on the way. Now we are getting into Fall and I need to think about heat. LOL! It never ends but I like it! I'm thinking I should just direct deposit my check straight to Wild Horses. I think my theme so far is inner beauty and outer ugly.
[Image: attachment.php?attachmentid=9169&d=1443726518]
[Image: attachment.php?attachmentid=9168&d=1443726518]
[Image: attachment.php?attachmentid=9166&d=1443726219]
[Image: attachment.php?attachmentid=9165&d=1443726219]
[Image: attachment.php?attachmentid=9167&d=1443726219]
I meant to attach those as thumbnails. Man the computer hates me I think.
You gotta start somewhere Smile
Fancy! Hope they work as good as they look!
  Latest Bronco Driver Cameo Bronco Biff 9 3,073 05-10-2017, 11:55 PM
  Bronco sighting in eastern Pendleton SC Crawdad 0 1,481 01-15-2017, 10:06 AM
  Bucking Bronco ParadisePWoffrD 0 850 01-18-2016, 12:18 PM
  Bronco new year resolutions wepuckett 12 2,738 01-03-2016, 11:52 AM
  Check this bronco out snipes243 5 3,382 12-29-2015, 08:58 PM
  Bronco Christmas snipes243 23 4,500 12-26-2015, 04:22 PM
  Who's Charleston Bronco made my local news? Bronco Biff 0 851 10-05-2015, 08:58 AM
  Ruff 76 I looked at today. Broncitis 20 6,120 09-05-2015, 08:49 PM
  The Bronco made the news today snipes243 8 2,078 08-24-2015, 12:45 PM
  Not a bronco but..... firefighter2134 4 1,611 07-11-2015, 10:10 PM
Users browsing this thread: 74 Guest(s)
