Thanks for the suggestion. I have a scanner and linked to forscan but it doesn't cover mode6. Torque supposedly supports mode6 and I'm gonna give it a try tonight.
The misfire was a bad plug wire. Ordered a set of Taylor wires. Should be here tomorrow.
Glad to see some of you workin on your junk. I was starting to think everyone on here had been raptured up and left me behind.
[quote=jstoppok]So I got the transmission and transfer case rebuilt. Yhey look great but the big question is do they work. I noticed the radiator was leaking when I was putting in the transmission cooler ( I refuse to admit I did it during the install). Then I saw the power steering pump was leaking so ordered a new HD one with brackets. Didn't like the original alternator so have a 3G on the way. Now we are getting into Fall and I need to think about heat. LOL! It never ends but I like it! I'm thinking I should just direct deposit my check straight to Wild Horses. I think my theme so far is inner beauty and outer ugly.
Looks great
Found a way to use Torque Pro to monitor mode $06 data including misfire. This is a major shortcoming of Forscan.
SETTINGS
MANAGE EXTRA PIDS/SENSORS
ADD PREDEFINED SET
FORD
Now many more PIDS populate on my graphs and dashboard.
Super cool!
^nerd level achieved
Where have you been? I achieved that a very long time ago. Thanks for noticing though.
Oh I have known, it just felt appropriate to announce it.
Good deal on the ODB-II software! I was back-reading the Chuzie's Monster thread. My wiring needs help and I read what you did with your switches and gauges. Man I'm running full steam trying to get mine on the road and now you raise the bar just high enough for me to clothesline myself. You seemed like such a nice guy in Charleston too. :lolup: Thanks for the great ideas and explanations.
The wiring would have been much easier had I taken the time to do it correctly to begin with. The price I paid for poor planning and laziness was 120 hours of cleanup. I don't recommend a rewire until you have your system to the point where you are somewhat confident you will not be adding additional circuits. That is the main reason I took the plunge after all these years.
Well i did get a start on getting the motor ready to put in but ended up making more work for myself. The Oil pump drive had been installed from the top and had no keeper ring on it and when I pulled the distributor it came the drive came out with the distributor. When I went to put it back in my clumsy self dropped it into the oil pan. Oh well I guess i will get a chance to look inside the motor tomorrow when I pull the pan to retrieve said evil shaft. Now I have to make some calls to locate a vacant engine stand.
  Bronco new year resolutions wepuckett 12 3,433 01-03-2016, 11:52 AM
  Who's Charleston Bronco made my local news? Bronco Biff 0 1,024 10-05-2015, 08:58 AM
  Ruff 76 I looked at today. Broncitis 20 7,102 09-05-2015, 08:49 PM
