09-15-2016, 07:45 PM
well it doesn't look like I'll have Sat free after all.
Nick
Nick
Nick
09-15-2016, 10:02 PM
That's fine. I read the workday memo and the plan is to spread more hay.
The October workday is one we should attend. Sounds like we will be moving rock from the double parking lot to Dutch John
09-16-2016, 04:31 PM
broncosbybart Wrote:That's fine. I read the workday memo and the plan is to spread more hay. Cool - - - more rock :doh:
10-29-2016, 07:08 PM
![]() Sent from my SAMSUNG-SM-G930A using Tapatalk
10-29-2016, 07:22 PM
Toss that junk and get a grizzly locker and upgrade to 31sp yukons while ur at it
10-29-2016, 09:48 PM
looks like a factory limited slip, cheap and easy to rebuild. Two rebuilding tips I learned
when I worked at the ford dealer. 1. Skip the additive, (back then it was called whale sperm) it makes it slip more not less. 2. To really get the clutches to grab put a very small washer (we used rivet washers) behind each of the 4 springs to increase pressure on the clutches.
10-29-2016, 11:00 PM
I know it's easy to suggest someone else spend a lot of $$$ but let me try to help you put it into perspective. I see the direction you are going with your rig. You like the rocks just like I do and I can say with absolute certainty, if you don't upgrade now you will do it down the road. Unfortunately, you will end up spending more to do the upgrade down the road once you add the cost of whatever you are going to do with it now not to mention the time and effort expended.
Do yourself a favor and go shopping. You can have that stuff at your door by Wednesday and installed and tested by next weekend and ready well in time for NovRun. Go big or go home.
10-31-2016, 08:49 PM
broncomatt Wrote:looks like a factory limited slip, cheap and easy to rebuild. Two rebuilding tips I learnedthat way...when it goes BOOOM- it will take out both shafts, and spit the main caps off, and split the 3rd. ask me how i know lol
11-01-2016, 01:34 PM
blazinchuck Wrote:that way...when it goes BOOOM- it will take out both shafts, and spit the main caps off, and split the 3rd. ask me how i know lol That wouldn't have anything to do with a heavy skinny pedal would it?
11-01-2016, 01:48 PM
Nope. Just a shitty mechanic
Bronco Christmas | snipes243 | 23 | 4,097 |
