show me your "anti wrap"
looking for some of your ideas please, i know i need to add one to my bronco. post up some pics too if ya can. thanks,Chuck
Mines pretty simple, but works really well. It is just a straight bar with heims at both ends. It is solid mounted to the top of the pumpkin and then to a bar that sits across the frame rails, there are no links. I can try to take some pics this weekend and post them up for you.
Nick
nhopman Wrote:Mines pretty simple, but works really well. It is just a straight bar with heims at both ends. It is solid mounted to the top of the pumpkin and then to a bar that sits across the frame rails, there are no links. I can try to take some pics this weekend and post them up for you.
Nick
that would be awesome Nick...thanks
Chuck, Here you go.
Pic 1 = mounted on top of the pumpkin. There is a 1/4" plate welded to the top, I didn't think the housing steel was enough for the stress the anti-wrap would put on it. the tabs are welded to the plate.
Pic 2 = tabs welded to a square tube welded to the frame. The anti-wrap bar follows the line the Drive Shaft takes.
Pic 3 = different view of the pumpkin mount.
Pic 4 = Where I mounted the square tube to the frame and it is also welded to the body mounts. the tube is a 2"x2" 1/4" wall
Nick
Here is the one I ran on my 9". I had solid bushings on the axle end and 2 hiems on the pivot/shackle. It stopped all my axle wrap and did not bind the articulation.
[Image: Tractionbar.jpg]
[Image: Tractionbarbracket.jpg]
[Image: Tractionbarshackle.jpg]
Nice and thick tube, bushings on axle end. 1/4 elliptical shackle on frame side. Mounted a few inches away from the pumpkin. Matched the driveshaft angle and worked awesome.
[Image: 1-nov-05-7.JPG]
[Image: 1-nov-05-3.JPG]
That isn't a Bronco. It can't possibly work... Actually Aaron's looks pretty slick. Otherwise, a link from the top of the housing to a piece of square tube acting as a frame crossmember is simple and easy. WH sells one that you might be able to get some ideas from. If you want, I might have their brackets that you could trace out to dupilcate.
  New paint and wrap cuz1 9 3,899 03-03-2012, 09:52 AM
  show me the flares blazinchuck 6 1,443 08-01-2011, 01:09 PM
  show me your... blazinchuck 9 1,546 12-25-2010, 02:09 AM
  ready for the show and shine.....hehe shon 8 1,586 03-19-2010, 11:42 AM
Last Post: shon
  Josh(Berg Bronco) show some pic of the new BUMPERS Mill Knob 33 4,925 01-31-2010, 03:43 AM
  small church car show. Crazy Horse shon 6 1,639 10-20-2009, 11:21 PM
Last Post: NGABronco
  Show us where it's at....(on the bronco) johnpaulgolf 34 5,215 04-30-2008, 10:51 PM
