'77 Bronco 4bt Conversion
This is pretty impressive to me:notworthy: Not to hijack or anything but what horsepower and torque numbers you get with this type of conversion. I'm pretty new to diesel, sounds like cool conversion.
The little 3.9L 4bt is tagged at a whopping 105hp @ 2,500RPM... and 260 lbs/ft of torque @ 1,700RPM.
Hope to some day take it to around 180hp and 400 ftlbs of torque. I plan to stay with the Bosch VE pump but will change out the turbo or modify the current turbo for increased rotor speeds (boost pressure).
It won't be able to take on those Ford engines in a race...but it should provide low rpm torque.
Confusedcratchhe:That's cool,man. Keep us posted on improvements. I love diesels!!:notworthy:
That is super nice. That is what I was wanting to do to my bronco whenever I get one is a 4bt conversion. :xyxthumbs:
02 VW jetta TDI/ 79 Chevy K5 on 1 tons/ 69 Ford Bronco
Thanks ... I'm definitely going to have to keep the exhaust work covered in MUD! Running this 4” exhaust has tested my patience...:banghead:....and has taken twice as long as I planned.....still have to install 2 hangers…
Finally got some BFG KM2 35x12.5x17 mounted to 17" rockcrawlers.... The Bronc is close to hitting on the roof when I drive it into the garage!
Man that thing is sweet...hope I can see it in person when I come to town next time.
johnpaulgolf Wrote:Man that thing is sweet...hope I can see it in person when I come to town next time.
Thanks you can stop by to see it any time.. Hopefully, it will be on the road real soon for extended drives... just recently installed the auxillary tank. That gives the Bronc a 26 gallon total capacity. So with a 22 MPG estimate we should have a range of 500 miles before needing to buy $4.25 per gallon diesel....
Here's some photos of the mag pickup & the Dakota digital signal converter for counting teeth on the flexplate. I needed to set the gap on the sensor before putting the C4 back in.. Hope to pickup an Autometer 5K RPM diesel tach soon... Don't laugh... 5K is all it needs... especially since the little diesel is governed at 2,800 RPM at the moment.. but we can improve that a little.. for $10.00 we can take it to 3,200 rpm!!! That's using over 60% of the gauge...Confusedcratchhe:
you will like that 3200 c'mon...I know I do!!!!
so when we meeting in person???? I'll be in the bronco tomorrow!!Chuck
ps...numbers in the who's who
  Bronco Camo Wraps circlefire 7 3,648 03-27-2018, 05:20 PM
Last Post: circlefire
  68 Bronco wepuckett 126 33,987 04-27-2017, 09:57 AM
  73 Bronco wepuckett 115 29,502 05-17-2015, 11:11 PM
  That storage locker Bronco 66Roadster 53 14,315 01-17-2015, 11:49 AM
  Wheels and Tires. Stock 1996 Bronco 5.8L 4wd or w/ 2" lift and poly body mounts. jrshepherd 2 2,518 05-10-2014, 02:36 PM
Last Post: Wickedlester
  1969 Bronco Build jtoney51 9 4,394 07-09-2013, 10:26 PM
  66 Bronco rebuild Casey835 56 15,255 06-04-2013, 07:45 AM
  my bronco build 66bronco 65 19,211 04-17-2012, 11:54 PM
  Just getting started 74 Bronco N747JB 7 3,134 10-29-2011, 07:59 PM
Last Post: N747JB
  BC Bronco shorty header install with 2-in-2 exhaust Crawdad 14 6,698 01-04-2011, 02:03 PM
