Toyota winch bumper
Here is a few shots of the Yota winch bumper that I am working on.It sucks that Toyota moved the bumper up so high but left lots of sheetmetal below the bumper line or this would be easy.That along with the wacky boxed ft ifs crap makes the outside of the frame rails 37.5 in wide. The endplates are 3/8th but are only held by 4 12mm bolts so I am adding 4 more bolt points to the ft structure @ the corners of the frame in the stock holes ( as seen in p 6 and7). There is a Warn hs 9500 winch going on here but it is way too big for this truck as it weighs 3-3500 lbs max. There will be lots of Hole saw work to make everything lighter and air flow but this one doesnt weigh much now but that big assed winch aint on it yet.
03 Honda Shadow Spirit
Looking good man..:biggthumpup: I want you to build me a bumper for my bronco..:notworthy:
I'm interested to see what you have up your sleeve for the corners. I'm sure I'll see when I get home. Confusedmokin:
George - You got it man :xyxthumbs:
