12-29-2008, 07:57 PM
I need help identifying heads. The casting # C80E where is the other letter?
carl
carl
Head identification
carl
12-29-2008, 11:24 PM
Do you happen to know if there is a -# after the C8OE? Early '68 302 4V engines had a C8OE-F casting with a small 53cc high compression head very similar to the HiPo 289's. Most of the others should be between 58-63cc. I'm not for sure if the emission bump in the exhaust appeared in any of these or the C9's. I know the D0's did.
| Rear end identification | 73Bronc | 11 | 5,557 |
04-03-2008, 06:00 PM Last Post: chuzie |
