Fayetteville shop
I need to find a gifted mechanic in the fayetteville area. Having some major trouble with my 77 bronco. 302 crate , holly ta 470, centech wiring, so its not a run of the mill factory setup. Need help. Someone who can troubleshoot either a mechnical but most likely an electrical issue.
Thanks
-J
Are you military? What seems to be the problem?
Failure is not an option!
I don't know who in Fayetteville to reccomend but a little ways up I-95 in Wilson NC is downeast off-road
Or if you wish I'd be willing to take a looksy. I'm North of Greenville NC. Many Many years ago I did reserve at Bragg. Took a little over two hours to get there
1974, 331 stroker, Holley TA,Dana20 twin stick w/terra low gears, 456 axle gears, detroit in the rear, true track up front ,MSD ignition, 37x12.50 PJs, 9k warn-tabor
Fedzone, NC-Ford
Thanks for the reply, looks like I found my problem, fuel pressue at 9 installed a regulator got it down to 7 and so far so good. Additionally I didn;t have the floats set low enough spent some time and learned about them. added .5 in clearance between the air cleaner cover and the TA crossover vent tube . Seems to be running fine now. I hope to make it to URE Nov 9th. Again thanks for the offer to help.
Jay
  ISO trusted shop partner in Concord area Obeg 1 1,746 09-15-2016, 06:32 PM
  Green Bronco in Fayetteville rtj731 2 2,040 07-01-2013, 10:27 PM
  resortation shop recommendations Brushmaster 1 2,296 10-20-2012, 07:41 PM
  Quality/Recommended Restoration Shop vmi2008 3 3,004 10-23-2010, 09:27 PM
  any tranny shops round fayetteville? c-dub 1 2,007 05-29-2010, 01:20 AM
Last Post: c-dub
  Check out my new shop tool ... 66stocker 8 4,121 09-02-2009, 11:07 AM
Last Post: abunchofidiots
  Upholstry shop near Hendersonville? 66stocker 6 4,543 08-13-2008, 03:28 PM
Last Post: 66stocker
  Help finding Mech Fayetteville rtj731 3 2,577 02-15-2008, 03:54 PM
