squeeling and rattling
I have a 79 and am having some issues. While in drive or reverse my idle is wacked and sputtering. when I actually accelerate its a noticable sputter which sometimes ends with engine failure. other times the sputter is followed by a loud squeel from the engine compartment and then a rattling noise. After that i usually get multiple back fires or something that sounds like a back fire. could it be my fuel pump/lines/filter? not sure but the sound also seems like it may be coming from one of my valve coversConfusedcratchhe:Confusedcratchhe:
Could something like the alternator or power steering pump be locked up?
[Image: Outalne_017.gif]
not sure, im kinda new at this so i dont know what to look for. are their any distinguishing signs of those things being locked up?
i would check the distributor...make sure its not loose. being a 79...shouldnt have points, but you never know what previous owners do. also look at the belts...they should be tight, should have no more than 1/2 inch of play.(to check) just press down on the belt between the distance of two pulleys.
Have someone sit in the drivers seat and put it in drive while you listen and look at the engine. It some what sounds like a water pump, alt or ps pump is locked up.
If it realy is coming from the vavle cover I would pull it off and check the rockers.
Keep us posted.
well the squeel does sound like a belt issue if you can do a tune up (fuel filter plugs wires cap rotor) its a start but inexpensive and always a good place to start check ur idle it could be set to low. I dont know much but I do have a 79 and this is where i would start. How does it idle in park or nuetral?
Lifes a garden dig it
