wow!
wow!!! the site looks awesome. when did this happen? Confusedcratchhe: i need to log in more frequently. so anyways...... i was wondering if this looks normal to anyone?
is that a trac bar bushing. i'd replace it . not normal. the bushing doesnt appear to be worn but instead smushed.
its the bushing to the axle pivot bracket.
I seems the bushing has swelled or split. It should be replaced.
X2-definitely!!! :xyxthumbs:
what would cause the bushings to swell? when i finished installing the bushings, i noticed they already had the gap in them. would prying the bracket a bit to put the arm back in have anything to do with it? also, i got the poly bushings from summit.
  WOW Summit is the Bomb 744x4 1 2,166 06-04-2011, 11:08 PM
Last Post: NGABronco
