sterling 10.25
so can anyone tell me what this is? would this be a stock posi unit? kinda look like this detroit i found, but it doesnt work like a locker...it works like a open rearend:banghead:
[Image: 4x4pics3538.jpg]
[Image: 4x4pics3539.jpg]
[Image: 4x4pics3540.jpg]
here is the detroit from Randy's
http://www.ringpinion.com/ProductDetails...ProdID=227
so much for that, i got some answers on pirate-looks like a detroit
if it was a detroit why does it act like it is open. will it behave differently under a load like a lock-rite? are you going to keep it in there and see what happens?
Well it says in the right up that it will act like an open carrier under no power ... when power is applied it LOCKS ... lets hope and pray ... :biggthumpup:
sounds like a bonus you didn't even know you had :xyxthumbs:
these are a few pics from pirate...
[Image: attachment.php?attachmentid=477721&stc=1&d=1257396368]
[Image: attachment.php?attachmentid=477722&stc=1&d=1257396368]
[Image: attachment.php?attachmentid=477723&stc=1&d=1257396368]
Quote:x2 that is a detroit locker. You can see in your middle pic a little bit of a yellow coil spring inside. The factory LSD (trac-loc) you would see a side gear, no spring.
Yours must be broken or jammed up, not unheard of.
Photo1 Sterling Detroit locker
Photo2 Sterling 10.5 trac-loc
Photo3 Sterling 10.25 open diff.
i just contacted eaton, waiting on some info for this axle and the locker.
Sorry bud, just saw this. Been working in the yard a bunch.
It looks like a detroit, it will allow the axles to spin oposit when not under a load.
If you have it in the axle, you should be able to spin the drive shaft and have the axles lock up. They usually have a wratchety feel to them when there unlocked.
Hope that helps.
ok, i talked with eaton today. load or no load...i detroit will not allow the other tire to turn opposite. if thats the case-its not a detroit. i just jacked it up again, and it is a detroit, it ratchets(very softly) and will lock up. i guess this one is worn pretty good. i can get new side gears from eaton and rebuild it too. so this is really good news and yes Robert-what a bonus!!!
a detroit locker for sure and they will not allow the opposite tire to ever rotate backwards. will make noise but not a problem.
