My Dually
Had a severe fuel leak :banghead:
Thanks to my new friends on http://www.powerstroke.org :notworthy: :biggthumpup: :notworthy:
I got it fixed :xyxthumbs: ... actually had two issues this fixed ... the fuel leak and the "water in fuel" light had been staying on alot Confusedmokin:
This is what they told me to do ... I did'nt exactly do the "rebuild" but bought the whole part cuz nobody had the o-rings in town (3 days out) so because I was leaking SO much fuel needed to be done TODAY :xyxthumbs:
http://home.centurytel.net/sabre/drainvalve.html
:biggthumpup: :notworthy: :biggthumpup:
Confusedmokin: Confusedmokin: Confusedmokin:
:rockon: :rockon: :rockon:
Boy JP looks like that was in a tight space ... Confusedcratchhe:
Glad you got your fuel leak fixed ... Confusedmokin:
johnpaulgolf Wrote:Boy JP looks like that was in a tight space ... Confusedcratchhe:
Yeah it was in a tight spot for sure :banghead:
Could only move the ratchet like one or two clicks at a time ... :banghead:
And yeah I'm glad I fixed it too ... it was like throwing dollar dollar bills right out the window everytime I was driving ... :biggthumpup:
[SIZE="7"]2x[/SIZE]:repost:
blazinchuck Wrote:[SIZE="7"]2x[/SIZE]:repost:
Yeah I'm proud of that fix for sure Confusedmokin:... and no "water in fuel" light this morning commute to work :biggthumpup:
Now I just gotta clean up the underside of my truck which is covered in fuel ... cleaned a little last night but not all :rebel:
:chili: :rockon: :chili:
:popc1:
Nice tech JP thanks for posting ... :xyxthumbs:
I actually keep a set of these o-rings and a set of torx bits in my truck. A few other o-rings you might keep around are for the HPOP lines, and the large plug on the back of the HPOP.
abunchofidiots Wrote:I actually keep a set of these o-rings and a set of torx bits in my truck. A few other o-rings you might keep around are for the HPOP lines, and the large plug on the back of the HPOP.
hmmmm ... 10-4 ... thanks for the ideas :biggthumpup:
These are the tires I'm thinking about ... Little bigger and kinda aggresive ... all 6 should look badeA ... what say you ? Confusedcratchhe:
http://www.tirerack.com/tires/tires.jsp?...R6KM2RWLV2
[Image: bfg_mudterrain_ta_km2_ci3_l.jpg]
Hey Jp how much and where did you get the part? a friend of mine is having the same problem.
  JP's Dually "Mod" pics added johnpaulgolf 34 15,157 11-29-2009, 06:20 PM
