Need some help
I have a 91 Infinity G20 and I am having some problems.
I posted this on the G20 site but it is kinda like pirate so I don't expect much but smarta**ed answers.
Ok while I was deployed my wife was driving my 91g20, one day it was running good the next it will not run at all.
I have changed the cap,rotor and wires. The plugs are fairly new so I did not replace them.
The car runs like crap, missing very bad like it is hitting on 2 or 3 cylinders. I started it today and it barely had the power to get up my driveway.
I am not sure where to go from here. Any good suggestions would be great.
Ok, let me add this. I have pulled the plugs after running and they all seem to be firing meaning none of them were wet with unburnt fuel. The fuel filter is good the air filter is good. I believe I need to get the car running before I can do a power balance test as you suggest right? Is there a away I can see if the injectors are at fault? Oh I have also replaced the coil.
Up date. I checked for codes and got 3 short and 4 long flashes my Nissan book says that is a knock sensor problem. I replaced that and it is still barely running and the code is still in the ECM.
Any ideas would be great
Paul
Got it fixed. I had 2 bad injectors. Went to the u-pull-it and got a fuel rail for 58 bucks installed the injectors and shazzam she runs like a top.
dang, sorry i didnt see this earlier...not sure if i could have helped. glad to hear its up and running again...good job Paul!
Users browsing this thread:
