06-22-2010, 01:05 AM
I have the chance of getting a 351m for $250, and it still runs great!! I know the stock transmission in my 70 won't work, so what are my options?
Help With 351m
06-22-2010, 07:52 AM
C6 and NP435 ... It'd be a strong running gear but it might take some work making it all fit and mount in there. That is a good deal on that motor.
06-22-2010, 10:41 AM
If it is an ''m'' it will take the 460 bellhousing.Tight fit in a eb but I guess doable.Back in the day a friend had an eb with a cleveland and it was real tight.
[SIZE="4"]Founding member of the "cheap bastards 4x4 gang''[/SIZE] ![]()
06-22-2010, 04:24 PM
I got a brand new Comp 255DEH torque cam for a 351M/400 I can part with.
06-23-2010, 02:10 AM
bucketobolts Wrote:I got a brand new Comp 255DEH torque cam for a 351M/400 I can part with.How much?
06-25-2010, 02:54 PM
sparkchaser Wrote:If it is an ''m'' it will take the 460 bellhousing.Tight fit in a eb but I guess doable.Back in the day a friend had an eb with a cleveland and it was real tight. Got an M in Mine, Radiator is moved forward. Still building it but it fits, you will need outside the frame headers for the exhaust, wont fit inside the frame rails.
06-26-2010, 12:21 PM
josephitguy Wrote:Got an M in Mine, Radiator is moved forward. Still building it but it fits, you will need outside the frame headers for the exhaust, wont fit inside the frame rails. ok thanks. |
