ABS Scan tool?
Anyone got an OBDII Scan tool that also reads/clears ABS codes. I messed up and didn't disconnect the battery when changin out rear hub assemblies on a darn Chebby... now the ABS light is on, presumably cuz it lost comm to the two speed sensors while I was changing them out (integral to hub). I am POSITIVE that I reconnected the sensors on the new hubs, so it's either this, or they sold me a bad hub assembly or two. Need to check/clear code to confirm.
Thanks!
JayT
Got one in my tool box in my barn, if you fancy a drive?
If the batt/ign/lights trick doesn't do it, I'll probably take you up on that, Matt when we come over for the wrench fest.
  Double Flaring Brake Line Tool?? SC74 6 3,918 04-13-2008, 10:54 PM
