Propane injrction hrlp
So I have the system all setup. I get a click from the solenoid attached to the regulator but it wont fire. The motors runs fine on gas. Any Ideas Sorry I know its a little vague. Trying to get it running for this weekend.
do you have a vacuum or 12v solenoid that turns the propane on? sound like your pane isnt being turned on at the mixer. mine was a vacuum...so it took about a second or two before the pane turned on(while turnning the motor over). pane is super easy!!
blazinchuck Wrote:do you have a vacuum or 12v solenoid that turns the propane on? sound like your pane isnt being turned on at the mixer. mine was a vacuum...so it took about a second or two before the pane turned on(while turnning the motor over). pane is super easy!!
There Is a solenoid before the regulator (the round part with the coolant lines running through it) I was told it was suppose to click when you turn the key on. which it does. After that, thats all i know. Also is the cone thing in the mixer suppose to be up or down when u turn the motor over?
i done know what you mean by "cone thing"...i think i remember a spring button on the mixer, but thats it. you have to make sure valves are open. tank valve and the one at the mixer
Got it covered. I did some digging this morning and found out how to prime the system. Did that and tweaked a few things and it fired right up. Are you running propane chuck? Thought you were EFI. Any idea of how much use you got out of a tank? I have a 10 and two 8 gal tanks. The 8's are full. Not sure how much the 10 has in it.
i swear, if you show up without a bronco.......
Hell yeah he will
glad to hear things are working now!!! looking forward to seeing all these broncos!
it's alive!!! if i had any fancy equipment, i would share some pics/video. otherwise, you'll just have to wait a day or 2 to remind me of all the things i forgot to do.....
good deal, cant wait to see it
  propane broncomania 23 9,349 07-04-2008, 01:59 AM
