tilt column
im looking to buy a tilt column for my bronco i have the floor shift and a t.b.p. steeering weel and have power steering with a ujoint steering shaft. wich bronco vendor sells the best setup and how hard is the install i already have the stock column out im just trying to decide who to go with!
I got mine from toms few yrs ago. Prolly about an hr and half install.
firefighter2134 Wrote:I got mine from toms few yrs ago. Prolly about an hr and half install.
what kinda wheel you have on it
the bronco logo wheel. i bought the complete kit. the wheel uses a grant adapter kit
I had one of Tom's units as well, was a complete kit with their Bronco logo wheel. Not too bad to install. I had to modify the firewall column support clamp, as the aftermarket columns are a smaller diameter than the stock column. Otherwise, no problems (provided you get their kit). You can piece it together, if you already have some of the parts.
do you guys find that you use the tilt that much?
personally, no. set it and forget it...
yup. Set it and forget it. But in same sense its nice to be able to tilt it up to get easier access under the dash
firefighter2134 Wrote:yup. Set it and forget it. But in same sense its nice to be able to tilt it up to get easier access under the dash
i didnt think of that!
  aftermarket tilt columns? also cruise control blazinchuck 19 6,577 03-06-2013, 07:41 PM
