Name That Part - round 2
Ok I am in the final stages of emptying the garage and found some loose parts that I do not want to discard without first identifying.
For size reference, this stuff is sitting on 2 paper towels.
Thanks in advance. ;D
Picture 1 HOOD LATCH (DUH) In here by mistake!
[Image: P1020828.jpg]
Picture 2
[Image: P1020827.jpg]
Picture 3 WEIRD BATTERY COVER???
[Image: P1020826.jpg]
Picture 4 ENGINE THROTTLE RETURN SPRING BRACKET
[Image: P1020845.jpg]
Picture 5 MUSTANG MOTOR MOUNT???
[Image: P1020835.jpg]
Picture 6 RIGHT REAR REFLECTOR BRACKET FOR TIRE CARRIER
[Image: P1020844.jpg]
Picture 7 LEFT WINDSHIELD WIPER COVER BRACKET
[Image: P1020843.jpg]
Picture 8 FENDER BRACE
[Image: P1020842.jpg]
Picture 9 QUARTER PANEL BRACE
[Image: P1020841.jpg]
Picture 10 FUSE PANEL COVER
[Image: P1020840.jpg]
Picture 11 COLUMN SHIFT LEVER
[Image: P1020839.jpg]
Picture 12 STOCK EFI THROTTLE CABLE BRACKET
[Image: P1020838.jpg]
Picture 13 WIPER WIRING COVER
[Image: P1020837.jpg]
Picture 14 TAILGATE POST ACCESS COVER OR FS FRONT BODY MOUNT COVER
[Image: P1020836.jpg]
Picture 15 LATCH BRACKET FOR CENTER OF LIFT GATE
[Image: P1020834.jpg]
Picture 16 WIPER DELAY BRACKET???
[Image: P1020833.jpg]
Picture 17 WIPER DELAY BRACKET???
[Image: P1020832.jpg]
Picture 18 MASTER CYLINDER BRAKE LINE SUPPORT BRACKET
[Image: P1020831.jpg]
Picture 19 WIPER ASSY. COVER?
[Image: P1020830.jpg]
Picture 20 CANISTER PURGE HOLDER
[Image: P1020829.jpg]
Some of it looks like it is not bronco specific. I'd throw that stuff out. There are a few things that come from the top of the windshield for supporting the electric motor wiring and motor cover. Those are in pictures 7,13, and 19.
Items in pics 8 and 9 are the tabs that hold the fenders and rear quarters to the body. They are removed once the fenders are cut for flares. It looks like you have 1 front and 1 rear there.
Pic 18 looks like the bracket that suppports a 76-77 proportioning valve. That is all I got. Anyone else?
The only things I would keep are the windshield wiper assy stuff. you could mount it back on, unless it is there already. I'd scrap the rest of it.
14 Looks like the front body mount cover.
pic 6= rear deflector mount for over the tire swing
pic 11=3 speed shifter column bracket
pic 11 goes inside the steering column for the shifter linkage. should have another one to match. takes 2 inside..
I know Pic 12 just can't remember since it's been so long since I've worked on a Bronco. I am thinking it's a throttle cable bracket. I think I had to modify mine for EFI cable? Does that jog anyone elses memory?
6 reflector mount for one with a swing away spare tire
7 is something from an eb door, cant remember what, but i have more if you want some
8 & 9 fender braces
14 is the acces cover from a full size bronco or pu. for the body mounts in the front.
19 is cover for something inside (dash or wipers) on an eb
15 is off a hard top latch
10 is a plastic cover off something ford truck, just dont rember what.
i think i have some of the same brackets on the floor of my shop if you want some more.
About time you guys chimed in! Thanks for the help.
#12 is a Ford 5.0 EFI cable Bracket like Robert eluded to
03 Honda Shadow Spirit
Awesome!!!
  Southern Rods AC kit install..part 1-heater blazinchuck 22 12,582 03-09-2013, 09:47 PM
  Heater box : Name that part! chuzie 8 4,557 12-29-2010, 11:26 PM
  Mystery Part- WTH is this? jdowns67 6 3,915 10-24-2010, 10:30 AM
  Trying to locate a driveshaft part 73Bronc 3 2,588 08-09-2010, 01:48 PM
