03-01-2011, 01:14 PM
(This post was last modified: 03-01-2011, 02:26 PM by GOODOLEBOY84.)
ok im thinking about selling my 66 but i dont know what to ask for it, i bought it about 2 years ago, 170 6 cyl 3speed, dana 30 and small bearing 9 inch with 4.10,s and a rusted out hard top, all the floor pans were rusted out and the right front body mount was rusted off, here is what ive done to it,
added electronic ign, replaced rf body mount, replaced the floors with 16 ga sheet steel, wildhorses 1" body lift, new poly gas tank and sender, new ss fuel line, new fuel pump with vacuum wiper hook ups, rebuilt the carb, new exhaust, added ps has the 4x4x2 box, power brakes, disc brakes on the front
built a winch bumper and has a off brand 10,000 lbs winch with synthetic rope, raceline suspension seats, roll cage, np 435, np 205, 34" super swamper ltbs 95% tread, slight rock rash not much tho, dana 44 with moser max shafts and ctm joints, 4.88 gears, lockright, f150 disc brakes, gm 1 ton tie rod ends and 1.5 dom tubing thats .250 wall, braded front brake lines, rear 9 inch is a big bearing 1977 model, new shoes and wheel cyl, has toms bronco 31 spline upgrade, full spool, has cv drive shaft in the front and rear, has the f250 shock mounts in the front, all lights work, 100% street legal, it drives good just not fast, it also has jeep coil springs in the front, the rear springs are stock they are worn out, so it will need new rear springs, ive put a lot of time and money into this bronco it is ready to turn the key and go ride, i think is time for me to move on to other projects, anybody got any idea what it would be worth?
