ECORS race 1- March 17 2012
We are going to try and make it with the Bronco. Even if we don't race, I'll be there. It is the first race of the 2012 series and is at the Flats, near Morganton, NC.
Event info is here:
http://www.nc4x4.com/forum/threads/seaso...nc.116406/
Guess I should add-
IF the weather is going to be lousy, I won't be going.
Right now the Bronco is sitting with the engine back in, but nothing hooked up yet. Got a lot to do. I think I can get it done in time. Will keep you guys posted.
What was the oil leak culprit?
I will be over this weekend to do some more work
Sounds good Clay! I (think) the oil pan was leaking. The original oil pan has little 'ridges' in it around the sealing surface areas. I think the one piece gasket didn't seal those areas properly. I put a new dual sump Mustang style pan on it and bolted it back together, along with a new pickup and all that good stuff. Hope it works!
broncosbybart Wrote:Sounds good Clay! I (think) the oil pan was leaking. The original oil pan has little 'ridges' in it around the sealing surface areas. I think the one piece gasket didn't seal those areas properly. I put a new dual sump Mustang style pan on it and bolted it back together, along with a new pickup and all that good stuff. Hope it works!
were there any ridges on one piece gasket that would match the ridges on the pan?
kinda, but the ridges in the gasket weren't near as big. the new oil pan is flat across the sealing surface. AND, it doesn't appear that it will contact the track bar- though it might contact the front diff.... Got to take the front springs out and set it to full bump to verify.
bumping this back up. I know a few are interested in watching. All are welcome to hang out in our pits if you want to. Our race is at 9am. We will be milling about for the later races, catching the action.
Final Bump for some racing action this weekend!!! We will be rolling out Friday. Hopefully about lunch time and do some pre-running. Looks like we will be the main event, with the A class scheduled for 1:30 pm Saturday afternoon. From the hype, it sounds like our class will more than double the others combined and we should have record attendance in A (ie- more than 20 rigs)!
Good luck and let it rip!
  WINDROCK or BUST - March 31st, 2017 !!! chuzie 30 21,166 04-14-2017, 03:01 PM
  Gulches day run - Sat March 28th chuzie 16 11,183 04-07-2015, 03:19 AM
  Raush creek 2012 snipes243 4 7,147 01-07-2013, 10:33 PM
  March Carolina Beach meet? bigredbronco 1 3,817 01-07-2013, 12:01 PM
  MEB Fawl Crawl Harlan, KY Oct. 12-13, 2012 nhopman 20 11,967 10-15-2012, 01:13 PM
  ECORS Race 8/25/12- Silver Valley, NC broncosbybart 16 9,890 08-27-2012, 09:45 PM
Last Post: nhopman
  6th Annual North GA Meet & Greet Sept. 15th 2012 NGABronco 1 3,325 08-16-2012, 05:34 PM
  Mud race tomorrow cuz1 3 4,954 06-06-2012, 11:20 PM
  MEB At URE - May 19, 2012 nhopman 18 10,974 05-22-2012, 09:57 PM
Last Post: UTFLIWGYA
  Going to URE Sat. May 5 2012 nhopman 7 5,648 05-07-2012, 11:08 PM
