Threads: 154
0
Threads: 154
0
Yes it seized my new motor...I am not saying anything bad about JBG just hope the next guy fairs better.
Threads: 38
0
I could say something bad about JBG but I just let my $$$ do the talking instead. They don't get any more of mine. Not so much the products purchased but the help they employed, or currently employ. I had a very difficult time with them.
Threads: 511
0
I'm very sorry to hear about this John, were yall not able to re oil the block and prime the pump? That really sucks!
Threads: 154
0
Chuck their was damage to my crank and two pistons seized on the wristpins. My crank and new pistons are in the machine shop now West Ashley. This rebuild has been a nightmare so far but it will only add to the story behind my FINE 69'.
Threads: 46
0
didn't you use the stock oil pump shaft? it should have had an spring metal washer like collar on it to keep it from moving up.. the real reason they did this was sometimes when you pulled the dist. out it would come out of the pump & drop in the oil pan.......man i hate that you burn up the new engine....
Threads: 154
0
DeTowman Wrote:didn't you use the stock oil pump shaft? it should have had an spring metal washer like collar on it to keep it from moving up.. the real reason they did this was sometimes when you pulled the dist. out it would come out of the pump & drop in the oil pan.......man i hate that you burn up the new engine....
yes it was the stock oil pump shaft...but that shaft was VERY stuck in the old distributor, had to heat it out... then we put it in the new distributor after priming the oil pump with a drill for 20 minutes... anyway it happened it sucks move on.
Threads: 511
0
has JBG said anything yet?
Threads: 154
0
yes they did...he said he notified the manufacture...i dont know... whay dont they sponsor our M&G? I see just about every other vendor.
