Dana 44 3.50
1977 Dana 44 3.50, in good shape, spindle to spindle,(housing, shafts and gears)
I used the disc setup for my project. MAKE AN OFFER
1977 Stock Radius Arms 50.00 for the pair
Drum Brake Knuckles in great shape 80.00 for the pair
Front Drum set-up all new,new set of front brake shoes, new front brake spring/hardware kit, new cylinders, self adjuster kit.. The drums are the only thing that have not been replaced... 80 for the pair
Manual Steering box, in good shape 50.00
Metal Dash, in decent shape 50.00
Emergency brake assembly, needs cleaning but in good shape 40.00
http://charlotte.craigslist.org/pts/3916630260.html
I will be glad to work with you on shipping, and deliver within reason...
I will also send pics, just shot me a pm with you email address..
Thanks for looking..
So to clarify, the 77 d44 does not have the disc brakes? Only the housing, shafts and gears? Are the radius arms off your 69 or do they go to the 77?
Crawdad Wrote:So to clarify, the 77 d44 does not have the disc brakes? Only the housing, shafts and gears? Are the radius arms off your 69 or do they go to the 77?
You are correct, Housing, Shafts and Gears, the radius arms are from the 77'...
Ill take the radius arms as long as they have the square holes for the anti sway bar. How far are you from Charlotte?
I will take a look when I get home and let you know.. If it does not have the sqaure hole, does that mean it's not a 77??
I am about 45 mins from Charlotte...
I believe the anti sway bar was an option for 76-77. I don't think they made it for earlier models. I have a set of radius arms off a 73 bronco and thought of drilling a hole and squaring it up. But I'd rather get the correct arms if possible.
I check the arms over pretty good and do not see any square holes..
Thanks
Jim
Oh well, thx for checking but I'm gonna pass on those! Good luck with the sales!
I am very open to offers, if you see anything your interested, through a number out... Thanks
Added a link to the craigslist ad, take a look at the photos....
Need to add the exhaust manifolds, off of a 351W in excellent shape... They have been painted, blasted and new studs installed
  DANA 30 KNUCKLES GOODOLEBOY84 1 2,896 05-02-2014, 09:33 AM
  460 engine parts and Dynatrac dana 60 front end cuz1 0 2,436 01-02-2013, 11:19 PM
Last Post: cuz1
