TA 470, Motorcraft 2150, CB 4x4 first pick
1. Holly TA 470 Truck Avenger carb $125.00 Sold
2. Motorcraft 2150 carb $100.00
3. 351 manifold $50.00 sold
4. 302 manifold $50.00 sold
5. Ford racing Valve covers $50.00
6. Ford Air cleaner $50.00
7. Receiver hitch $75.00
8. New 4 each 16 x 35 pit bull rockers tires, never mounted. (You will need these for the Nov. run)
Also I have an excellent set of cromo axle shafts, (Yukons) for D44 (make offer) Sold
All can be delivered to the NOV run.
J
I'd like the TA carb, if in good shape.
Price on shafts? Thanks!!
Will you be at the URE workday this Sat?
broncosbybart Wrote:I'd like the TA carb, if in good shape.
Im trying to get things sorted out if so I do plan on being there Sat, I'll bring the Carb and shafts we can look at them. As for the shafts what do you think is a fair price?
Shafts have 760 joints or yukons? I'll take a spot in line for shafts
Sent using my HTC ONE via Tapatalk
Chuck, I'll have to check but off hand I believe there 760
Chuck, you can have em. You could use them more than I need them.
I could prob use the valve covers. Is the receiver for an EB? will it bolt up to existing holes?
Not sure of your question but I did run these on a stock 302
I think those are 2 separate thoughts tied together. Sounds like the valve covers and then the hitch/mounting locations. The blessings of My ADD...
dixieboyz13 Wrote:I could prob use the valve covers. Is the receiver for an EB? will it bolt up to existing holes?
Yes the receiver is for EB I know it fits with a stock tank, not sure if it will with after market 23 gal or so. I have the backing plates that go inside the frame but not the actual bolts, lost somewhere in the mess I call a garage.
