33x12.50x15 Destination MT tire/28 spline axle shafts/V8 Frame horns- CHEAP
I think the axle shafts are large bearing- I forgot to check. I can measure them if you want them. $20 for the pair. *2 pairs available
The tire has like new tread. These tires have a ton of tread on them from the factory. It looks like there is at least 3/4" of tread depth on it. There is still some paint lines on it from being new. However, it does have some rock rash along the one edge, strictly in the tread. It holds air and the beads are in good shape. I don't need it. $60 for it.
I set of 302 engine mounts. These are the frame horns that were cut off of my 67 frame, as I'll be fabbing some up for the diesel. $20 for both.
Delivery is possible to the meet and greet or the super cel.
i might need those motor mounts, heck i might try and get that tires...its the same as i have now
Ok, let me know. Off topic, but I sent you a PM asking for a club roster for Terry with the USFS and our adopted trail. Thanks!
I need a tire for a spare for my son's truck. Where are you located?
  ARB RD55B 31 Spline Air Locker- NIB broncosbybart 3 4,485 08-08-2016, 05:33 AM
  Stock spare tire swing arm- rim attaching brackets and hardware BucknEB 1 2,427 11-18-2015, 05:10 PM
  33x12.50x15 Mud terrains nhopman 12 7,508 11-05-2015, 02:34 PM
Last Post: G-Money
  Stock Bumper, Hitch, Spare Tire Rack, Wheel JimR 0 2,132 06-10-2015, 11:12 AM
Last Post: JimR
  big bearing EB rear axle housing blazinchuck 7 4,919 04-22-2014, 06:16 PM
Last Post: Carolinaoffroad
  9" 3rd w/ 3:50 gears and 28 spline. BucknEB 2 1,966 02-10-2014, 06:34 PM
  Warn right inner axle shaft $150 Carolinaoffroad 1 2,635 03-07-2013, 07:43 PM
  Several Free/Cheap EB Parts and a few expensive ones broncosbybart 20 9,401 01-20-2013, 10:47 AM
  Axle and Diff parts nhopman 13 11,891 11-27-2012, 10:52 PM
  33x12.50x15 Bias TSL's and 5x5.5 beadlocks broncosbybart 1 3,441 10-22-2012, 08:39 AM
