2 abandoned broncos.
Run great. Free to a good loving home.
Sweet, I'm on the way to pick em up!!
What's up with Doug's rig? Did the engine survive?
I don't know about that green one. Heard it's been cussed at an awful lot by the mechanic! But hey, it's more than what I've got!
They have both been problem children. Either way, they are headed out to pasture (scrap yard) if they aren't claimed by the weekend. What does scrap metal go for these days; $0.07/pound?
broncosbybart Wrote:Sweet, I'm on the way to pick em up!!
Yes. We pulled and tore down the pump for assessment. Found a small chip of metal stuck to the ID of the outer pump gear. This was enough to prevent the inner gear from rotating which caused the shaft to shear. We were unable to identify the source of the piece but it was too big to be picked up and passed through the strainer.
Runs great and all seems well. If the cam bearing were damaged, only time will tell.
Where are theese located and if you need help getting one back game to help if it is is in SC some where, FL would be a bit of a drive for the weekend. There are some great parts I could use there if you don't plan on taking both Charles let me know or if you need help getting them.
....hmmm funny, I appear to have that exact location locked in on the GPS!! I could bring two tow bars and hook them up in tandem and make the east trek back up I95 no issues!!!
:xyxthumbs: ROCKNROLL!!
Is this real and are they already claimed, if not I can come this weekend to pick one up.
This is chuzie's attempt at humor. Me thinks he should just stick to flying.
So, in an attempt to get this back on a serious note, maybe the common theme going on is the mechanic? Big Grin
Sadly, the 3 people this was aimed at likely have no clue.
