Bertolini's '71 build
Brian Bertolini finally came around to getting some much needed work done. its a nice clean '71...he already had someone do a nv3550 swap, and a ford racing 302 crate motor and complete front disc conversion. this build will include...
Centech Harness
5.0 EFI conversion
WH's Sherman efi tank and BC fuel line kit
WH's complete 2.5" lift kit(minus leafs-those came from BC Broncos-9leaf springs)
H4 head light conversion and night lighter harness from WH
WH tunnel cubby fitted with triple gauges and power ports
Hellwig front sway bar(non-disconnect)
paint engine bay satin black
paint 302 red and all alum parts will get fresh alum paint.
post pics soon...
[Image: 02cead4318fe2d79bd3b8b95a8970f5b.jpg]
[Image: 23ed8a9c19e179c11af8af3b1f1a7abb.jpg][Image: 4518c058f78ab40ee46b5cb8f2b786d3.jpg][Image: d57b3a4cef2f0d2f448a977c5c635f0f.jpg][Image: 1b30d261792aeb87337b0805570b531c.jpg][Image: ea58f09e7eefda12c3f24082354826bf.jpg][Image: 5331bfa9f6113025baef3f1f5ac6984e.jpg][Image: 705ab4b044fdbef9f69774259b49a485.jpg]
Looking forward to the progress pics. Nice Bronco...
[Image: b42e27393a4bb6675841fdf2210fa2e2.jpg][Image: 0c2594fee34431f8d30b0ba27687d04d.jpg][Image: eae70762a955df643324bc824727a48f.jpg]
Got the rest of the new 2.5" lift done, also installed the efi fuel tank and new lines. Found some bad rust in the floor boards, so I need to order new ones and install them along with everything else
Btt, got Alot done in the pass two weekends. Cleaned all parts, painted motor, serpentine system, and intake. Installed the motor, nv3550, and d20. Almost got the centech wired in. Installed the rjm harness, tucked it in behind the intake for a cleaner look. Fuel system is done. Almost fired it up today!! Think it's off one tooth and we ran out of time...I got called in tonight. Also the cage is out so I can begin new floor boards[Image: 5a1a86bf18c8c1ee3ce7672b3c5e7979.jpg][Image: 2c414fdc7388cace20926785ebc7c380.jpg][Image: 2d0a619b7c2299dfa703787ffd63e28a.jpg][Image: ebc34a99be56e255d9fc9a7e9acd4885.jpg][Image: 893a34381286a9199e97911e454c49e2.jpg]
  my full width axle build 5/23/07->10/28/07 blazinchuck 627 293,783 01-14-2011, 06:38 PM
