77 wheel hub
I think my hub is damaged causing bearings to die. Want to swap out the hub and see what happens. I will take the hub or the hub/disc assembly if it's in good shape.
Thx.
New wheel hub from Rock Auto
https://www.rockauto.com/catalog/moreinf...524&jpid=0
Whole assembly
https://www.rockauto.com/catalog/moreinf...25&jpid=13
Those are a bit spendy. Maybe i will swap the hubs side to side and see if the problem persists.
It better not fail this weekend
Do you need a spare wheel brought up for the weekend Chuzie I got like 4 35x12.50x15 mounted on rims with fair tread sitting here with 5 x 5.5 bolt hole patterns.
William do you have a spare hub assembly?
snipes243 Wrote:It better not fail this weekend
I carry spare bearing in my kit.
wepuckett Wrote:Do you need a spare wheel brought up for the weekend Chuzie I got like 4 35x12.50x15 mounted on rims with fair tread sitting here with 5 x 5.5 bolt hole patterns.
Thanks but I'm covered.
For disc or drum, as I have a couple front axles but not sure of the conditions of either
You sure don't need a spare Chuzie
Disc. I flipped a coin. It was heads so I'm taking the risk. Ain't skeered!
  Wheel Spacers wanted 66Roadster 1 2,067 08-26-2015, 01:31 PM
  Stock Bumper, Hitch, Spare Tire Rack, Wheel JimR 0 2,128 06-10-2015, 11:12 AM
Last Post: JimR
