5.0 vs 5.8 Factory Exhaust
Would Factory Exhaust from a 1995 bronco 5.0 fit a 1995 bronco 5.8L I see Bronco Graveyard sells Magna Flow part# 93307 for a 5.0
Thanks for your help.
While the heads are the same so they would bolt up. The 5.8 is a windsor block. That has a wider deck. The angle MAY be different. Certainly the Y pipe will not fit.
  Single or Dual exhaust? Broncitis 6 4,432 05-07-2015, 10:29 PM
  Exhaust question Casey835 27 14,947 08-16-2013, 06:03 PM
  exhaust backfire? berg bronco 19 9,810 07-15-2010, 11:12 PM
Last Post: berg bronco
  Help !!! Caused an exhaust leak johnpaulgolf 10 6,673 09-25-2009, 09:46 AM
