BC Bronco Soft Top
Hey folks, trying to decide on a roof, and really dig the soft top from BC broncos. Just wondering if anyone has one or had one and what your thoughts are on it. It looks pretty slick but I was curious if its fairly easy to remove and put back on, as it seems like you'd have to install the frame each time you wanted to use the whole top, or if its designed to leave the frame on and just remove the canvas. Any input would be cool, open to other suggestions.
I know Chuck and Charles both have a BC top, sure Charles gots a bronco currently with 1 of each top available. Maybe they will chime in, as far as looks I spent this last super cel walking around looking at tops and BC is the one I plan on going with as I like the straightness or flatness of the top, they also offer a roof rack for it now but that is another story.
I really like the BC top but I don't plan to ever remove it entirely. By far it is the hardest to install. I think blazinchuck removed his by unbolting it from the bed rail and windshield frame and leaving it all intact. The canvas is very tight and a bear to work with.
i love my bc top-best top for sure. i think they are still too pricey for what they are. i remove the sides all the time-they are the easiest to take off and reinstall. i removed the top once and it was a huge pain in the arse, the top is too tight to stretch. i have unbolted it just like a hard top to remove it as one-ill do that before just removing all the fabric...because with the family cage and bc top frame, it looks way to busy for my taste with no fabric.
  1996 Ford Bronco- Body Bushing Install jrshepherd 2 2,184 09-19-2018, 02:50 PM
  Stainless/ Coated Headers needed- 1995 Bronco 351 Windsor .20 over trick flow heads jrshepherd 1 3,059 05-22-2018, 09:38 PM
  1977 Ford Bronco rear ended 9" rebuild Crawdad 10 4,680 01-19-2017, 12:53 PM
  1996 Bronco New BSD 4" long arm lift on IFS suspension- Setting Wheelbase jrshepherd 11 3,425 01-31-2016, 03:55 PM
  Another Bronco Floor Replacement jdowns67 83 12,248 12-20-2014, 11:33 AM
  Mystery Bronco, need your expertise to solve 1st Bronco 2 2,717 08-04-2013, 10:48 PM
Last Post: 1st Bronco
  OK. I love my Bronco again Timstrk 3 2,335 05-19-2013, 08:43 PM
  Bronco Help Around Greenwood Jbass 29 11,983 01-20-2013, 03:16 PM
  Bronco techs in/near Raleigh? Mbowles 10 2,239 11-30-2012, 07:07 PM
Last Post: Mbowles
  Looking for Troubleshooting Tips for a 79' Bronco Rear Window (Powered). UTFLIWGYA 5 4,176 10-29-2012, 05:41 AM
Last Post: UTFLIWGYA
