1996 Ford Bronco- Body Bushing Install
Good Day. Im sure one of you can guide me in the right direction. Im replacing the body bushings on my 1996 Bronco. I need clearance under the hood. My new intake is hitting the firewall Question: What is the best method of body bushing bolt removal? I have the nuts off. The bolts seemed fused into the original black rubber body bushings. I have a two post lift, skills (Some) and tools. Thanks for your help.
Try a round chisle and a hammer. It also helps to jack the body up a few inches and then hit the bolt with the chisle.
dont forget, you might be able to fit a sawsall blade between body/mount and mount/frame...ive had to do that too
  Stainless/ Coated Headers needed- 1995 Bronco 351 Windsor .20 over trick flow heads jrshepherd 1 3,059 05-22-2018, 09:38 PM
  1977 Ford Bronco rear ended 9" rebuild Crawdad 10 4,680 01-19-2017, 12:53 PM
  BC Bronco Soft Top knoxville714 3 2,912 07-12-2016, 08:04 PM
  1996 Bronco New BSD 4" long arm lift on IFS suspension- Setting Wheelbase jrshepherd 11 3,426 01-31-2016, 03:55 PM
  Another Bronco Floor Replacement jdowns67 83 12,248 12-20-2014, 11:33 AM
  Radius arm bushing cause of grinding/vibration sound? 1st Bronco 7 1,675 09-13-2013, 09:47 AM
  Mystery Bronco, need your expertise to solve 1st Bronco 2 2,717 08-04-2013, 10:48 PM
Last Post: 1st Bronco
  OK. I love my Bronco again Timstrk 3 2,335 05-19-2013, 08:43 PM
  cummins to a ford small block standard trans adapter plate Rdnckdemo 2 1,062 04-14-2013, 01:19 AM
Last Post: Rdnckdemo
  Southern Rods AC kit install..part 1-heater blazinchuck 22 6,001 03-09-2013, 09:47 PM
