Pitman arm bushings? and a couple other suspension ?'s
So I've got a slight lean in the rear driver side, due to the leaf spring coming undone, and was wondering if those are generic ford springs that i could maybe pull from an old F series or need to get new ones.
Also, I've got the wobble in the steering right around 40-45, and past that, the front end just starts hopping all over the road. I've been told the bushings on the pitman arm are worn, but I can't find bushings that are called "pitman bushings" anyone know if they're called something else? thanks gents
No such bushing on the pitman arm, this is a solid metal joint between the steering box and the drag link. Its more likely the drag link end (joint) has
worn out. Another common vibration in the front end is a worn track bar bushing.
As for the rear the leaf springs are specific to the bronco, any one of the bronco venders can supply them.
As Matt said, the track bar bushings are a usual suspect.
The early Bronco leaf springs are 2.5" wide. The full size Bronco and F series stuff are 3" wide. A spring repair shop might help but I don't know that for certain. The wild horses rear springs are awesome but not cheap.
I have a set of original Springs i dont need. Also have some new 3.5 lifted springs from JBG.
  1996 Bronco New BSD 4" long arm lift on IFS suspension- Setting Wheelbase jrshepherd 11 3,425 01-31-2016, 03:55 PM
  C- Wedge bushings snipes243 25 6,733 08-14-2015, 12:01 AM
  Radius arm bushing cause of grinding/vibration sound? 1st Bronco 7 1,675 09-13-2013, 09:47 AM
  suspension seats snipes243 4 2,541 03-04-2011, 01:26 PM
  suspension setup GOODOLEBOY84 0 1,480 01-18-2010, 01:25 PM
Last Post: GOODOLEBOY84
  RADIUS ARM BUSHINGS chulo2004 4 3,186 08-21-2009, 11:12 PM
Last Post: chulo2004
  90 bronco- couple of things john90 11 3,072 08-05-2009, 01:21 PM
Last Post: 2000F150SAS
  I need to know the Radius Arm width. 2000F150SAS 0 808 06-17-2009, 10:00 AM
  Looking for a couple tech how to's UTfball68 1 2,923 04-08-2009, 01:06 PM
  axle pivot bushings chulo2004 3 1,123 12-09-2008, 11:51 PM
