Radius arm bushing cause of grinding/vibration sound?
Had a mystery vibration/grinding sound for couple weeks. Never consistent when it would occur and never could find the reason for it.
About 2 miles from the house it came and only went away when I drove under 30mph. Called the whole family to join me in the search
under my 1985 Bronco. My wife said that rubber thing is broken....here is what I found at the end of the passenger side radius arm.
Do you agree this could be the culprit? Replacement comes in tomorrow and should know for certain.
[ATTACH=CONFIG]7347[/ATTACH]
[ATTACH=CONFIG]7348[/ATTACH]
[ATTACH=CONFIG]7349[/ATTACH]
VIN# makes it a 1985, the engine block# is an 1989, and the front end is from a 1987. I call it Broncenstein. [Image: bronco.gif]
It looks like you are in the right direction. if not the problem they most likely contributed to some noise.
[Image: Outalne_017.gif]
Well the new bushings are on and the grinding continues.....either u joint or wheel bearings......need time, few specialty tools, and some cash.Maybe next week.Confusedhrug:
Wheel bearings! Grab top of tire and try to shake it in and out. Ur looking to see if it rocks in and out
Sent using my HTC ONE via Tapatalk
Wheel does not shake holding top and bottom of tire, but grabbing at 3 O'clock and 9, it does shake side to side. Maybe ujoint, need to see if it has play in it.
I wouldn't be so concerned about u joint. If it's rocking while ur holding 3 &9 o'clock pos...sounds like a tie rod end is shot...does the grind lessen with brakes applied? Grinding get worse while turning? Or grinding get worse while braking? What yr bronco? Manual or auto hubs?
1985 body with a 1987 front end. Grind lessons when brake applied or coast slower than 25mph and stops below 20mph. Manual hubs, same scenario in 2x4 and 4x4. There is no grinding when using the brakes. Would tie rods make a "oh my God, what is that grinding noise"?
Thanks for your help.
No, but if the noise kinda goes away when braking.. I'm leaning towards wheel bearings. I bet the brake pads are trying to make rotor run truer. Check bearings first. If they not slap wore out, they probably need repacking hth
  1996 Ford Bronco- Body Bushing Install jrshepherd 2 2,195 09-19-2018, 02:50 PM
  Pitman arm bushings? and a couple other suspension ?'s knoxville714 3 2,928 09-16-2016, 08:10 AM
Last Post: Deltabronco
  1996 Bronco New BSD 4" long arm lift on IFS suspension- Setting Wheelbase jrshepherd 11 3,434 01-31-2016, 03:55 PM
  The 5/16" square hole in 76-77 radius arms Crawdad 3 2,966 01-14-2015, 12:38 AM
  Grinding sound from rear end area when driving Crawdad 10 4,178 02-09-2013, 09:33 PM
  Extended Radius Arms cam coffee 19 3,146 11-27-2011, 09:58 AM
Last Post: Timstrk
  Rear end vibration 73Bronc 12 2,937 11-13-2011, 01:27 PM
Last Post: cam coffee
  bushing install ? firefighter2134 2 2,583 08-11-2011, 10:30 PM
  Horrifying sound coming from my Bronco!!! chuzie 10 1,861 12-20-2010, 10:21 PM
  Vibration after 60mph cavscout 8 1,607 10-22-2009, 09:36 AM
