My little mule, Pe'pe - broncomatt - 06-23-2015 More progress, bed liner rolled on. Matched perfect and then painted the dash after drilling the holes for the gauges. Once it was mounted it was time to put the main cage back in. Stripped some of the engine parts down and painted them, should have the engine ready to go back in over the next few weeks. My little mule, Pe'pe - broncosbybart - 06-25-2015 Keep it up- at this rate you'll easily be ready for the NOV run!! My little mule, Pe'pe - snipes243 - 06-26-2015 Looks good Matt My little mule, Pe'pe - Broncitis - 06-27-2015 Nice looking work you are doing. My little mule, Pe'pe - lilpanther - 07-05-2015 It looks great with the blue bed liner and the yellow cage. My little mule, Pe'pe - broncomatt - 08-08-2015 Been a while but I got lots done. Resealed the engine, new dampener. Nerf bars are welded on and the engine cage is ready to go back in. Pressure washing the last of the parts to go back in. Put the engine back in. I guess pics wont load so will just have stay tuned to see what gets done next. My little mule, Pe'pe - broncomatt - 08-09-2015 The photos to bring everything up to speed. My little mule, Pe'pe - chuzie - 08-09-2015 Looks great. Can't wait to see it at NovRun this year! So what's up with the ps pump and the over spray? Sent from my GS3 on Cyanogenmod with the older / better version of Tapatalk! My little mule, Pe'pe - blazinchuck - 08-09-2015 im digging the primer looking engine bay lol My little mule, Pe'pe - broncomatt - 08-10-2015 The engine bay and all of the underside is SEM gray paint. Shiny and very tough, I felt it would be easier to touch up than the oem paint I used. I do need to clean off the overspray on the axle. There is no ps pump yet, its on a bench waiting for me to clean it up. |
