Another Fine 69 - Printable Version +- Carolina Broncos (https://cb4x4.com) +-- Forum: 66-96 Ford Broncos (https://cb4x4.com/forum-7.html) +--- Forum: Bronco Tech (https://cb4x4.com/forum-40.html) +---- Forum: Build Threads (https://cb4x4.com/forum-11.html) +---- Thread: Another Fine 69 (/thread-2198.html) |
Another Fine 69 - blazinchuck - 10-15-2012 cant wait to see it next month!! Another Fine 69 - firefighter2134 - 10-15-2012 here are a couple of pictures. the flex pics are with the stock springs. the other two are the new stance of the rear with new springs. i plan on moving the rear flares up to match the front closer to the body line also. Another Fine 69 - firefighter2134 - 10-16-2012 so tonight i got everything loose to drag front axle out from under bronco to change c bushings. hope to have it ready to slide back under tomorrow night. Another Fine 69 - firefighter2134 - 10-18-2012 trac bar drop bracket mounted, new bushings installed and axle back under rig. tomorrow just got to do front brake line drop pitman arm and bleed brakes then take her for a test spin. still have to get ebrake cables and shocks but itll be back on the wheels. pics upcoming Another Fine 69 - JayT - 10-18-2012 Lookin good!! Sent from my Nexus 7 using Tapatalk 2 Another Fine 69 - firefighter2134 - 10-18-2012 bronco sets on its own again! got drop pitman arm on everything else back in. i removed front driveshaft to have it extended. still have to bleed brakes, get shocks, ebrake cables and weld trac bar bracket. I even got a new tag for the front!!enjoy a few pics. Another Fine 69 - chuzie - 10-19-2012 Looks great. Should have no problem getting that short list accomplished before Nov. Keep it up and look forward to seeing ya! Another Fine 69 - firefighter2134 - 10-20-2012 i got front driveshaft extended today, will install it tomorrow, brakes are bled. pulled it outside to check measurements for shocks and to see the some flex. Another Fine 69 - firefighter2134 - 10-23-2012 Trac bar bracket welded. Now the list is down to shocks and e brake cables Another Fine 69 - chuzie - 10-23-2012 E-brakes are for chumps. Do the shocks and call it a day! |
