the 77's upgrades - blazinchuck - 10-31-2011 thats very similar...i wonder if they started cutting the angle on the leading edge of that bracket to clear sticks? the 77's upgrades - blazinchuck - 11-07-2011 got a few things done this past week... 1) recalibrated my fuel sender unit(used to barely go past 3/4@ full, and go way below E and still have over 5gal in tank) today it went just past full and should be just below E for empty. 2) bought and installed new WH's 3.5 11 leaf springs(they came with extreme 9/16th ubolt kit and shocks) 3) installed a storage box from FBG(right behind the rear seat) 4)replaced the front driver side caliper 5)installed a new CB antenna with quick disconnect for parking in garage might try to install a "line lock" soon the 77's upgrades - dixieboyz13 - 11-07-2011 How much do you want for your old springs? the 77's upgrades - blazinchuck - 11-07-2011 dixieboyz13 Wrote:How much do you want for your old springs? sorry Bard, a buddy of mine locally is buying them the 77's upgrades - chuzie - 11-07-2011 Bard :hysterical: the 77's upgrades - blazinchuck - 11-07-2011 chuzie Wrote:Bard :hysterical: :banghead ![]() :thefinger: chussy ![]() the 77's upgrades - chuzie - 11-07-2011 :thefinger::thefinger::thefinger: :thefinger::thefinger::thefinger: :thefinger::thefinger::thefinger: :thefinger::thefinger::thefinger: :thefinger::thefinger::thefinger: the 77's upgrades - blazinchuck - 11-29-2011 got me a driver side 79 F150 inner/outer axle shaft. replaced the u-joint with a new spicer today. ill try to get it installed tomorrow. this is a simple upgrade to the larger u-joint(760 vs. 260) the 77's upgrades - blazinchuck - 02-10-2012 planning to rip the front suspension out this weekend. i keep taking measurements and nothing seems right. 1/16th here,1/8th there, and even 1/2" in another area. so im gonna try to straighten some things out. hoping to solve the bronco lean too the 77's upgrades - blazinchuck - 02-23-2012 thanks to bart...i got the eaton e-locker for the d44 today! got a painless 6 rocker style switch panel from shawn.gonna be some nice upgrades very soon. installing 4.56 gears, LED rock lights, on board air/tank |
