My little mule, Pe'pe - snipes243 - 03-07-2016 Looks good what sneakers did you get? Sent from my iPhone using Tapatalk My little mule, Pe'pe - broncomatt - 03-08-2016 I have done a few windshields, by my self its too hard. Plus if it brakes going in, its there problem to replace it. Once the front bumper is on, then the winch wiring needs finishing. Bumper lights, windshield frame lights, back up(and underside) lights. Speakers and amp (Ipod for tunes), The speakers are going in the door panels with lights where the window crank used to be. The last part will be the soft top and soft doors. After reviewing my setup I'm changing how the posts are on the window frame. Going to make them adjustable so they will be easier to put in. I will flat tow it too TN, I could drive it but not having a good chance to do a shake down I will drag it up there. If it brakes I can still get it home and be back to work on monday. My little mule, Pe'pe - broncomatt - 03-08-2016 snipes243 Wrote:Looks good what sneakers did you get? There Pro Comp's 35" and same brand on rims. My little mule, Pe'pe - chuzie - 03-08-2016 Which procomp rims? I'm thinking about a set but they gotta take a beating. Sent from my GS3 on Cyanogenmod with the older / better version of Tapatalk! My little mule, Pe'pe - broncomatt - 03-09-2016 Rims are procomp's PCW-97 series. Steel with 8 good size circles cut in it. Looks like the aluminum of the same style. They wouldn't mount the 35"s on the 8" wide wheels. But i had a local shop do it for me. I think if I had gotten them from another vender besides summit I may not have had that problem. But they had the best price with free shipping. Just a $40 charge for over size. My little mule, Pe'pe - blazinchuck - 03-09-2016 4wheel parts mounted and balanced, shipped on a pallet....my 35's and rims My little mule, Pe'pe - broncomatt - 03-10-2016 Summit was going to do that for me, but when they saw the size of the rim (15x8) they said they couldn't. It was still the best price, so in the end it was worth it. My little mule, Pe'pe - broncomatt - 03-10-2016 Got the brakes dialed in, the steering is almost done. For the first time in 2 years its sitting on its own meats. Bumpers are almost done. Looking forward to seeing the windshield done. My little mule, Pe'pe - wepuckett - 03-10-2016 Nice looking forward to seeing it at Super Cel, maybe if I get the job I interviewed for today I can get mine on track to get on the road some time. My little mule, Pe'pe - broncomatt - 03-20-2016 Down to the last of the big stuff. The front bumper was cleaned up and went on with no issues. The winch is re wired and working. The rear bumper however didn't fit on. The fuel tank is new and my old trailer hitch would not fit. Stripped down to what would fit and using a new hitch built it back again. There are tabs for a skid plate to go under the fuel tank. Inside door panels and glove box door will be done this week and other than some lights and audio stuff is nearly back together. Picked up a 35" spare for 60 bucks! Nearly new 35 goodyear mtr. Time to dig out a soft top for him. |
