My little mule, Pe'pe - broncosbybart - 03-20-2016 Almost done! Looks great (for a him)... My little mule, Pe'pe - broncomatt - 04-03-2016 Mostly back together! Need to finish the skid plates few small bugs to work out but otherwise ready to go. Will put the soft top on this week. Very happy with all my designs. Will spend next weekend tuning the carb/engine. Will see you all in TN! My little mule, Pe'pe - broncosbybart - 04-04-2016 Nice work! You've got a week- slap the EFI on her ![]() My little mule, Pe'pe - Crawdad - 04-04-2016 Great job Matt! One of these days I'll be in ur shoes! A wonderful bronco! Matt My little mule, Pe'pe - broncomatt - 04-17-2017 Over the last few weeks I have had some time to take care of a few things. Fixed the dent I put in the right rear quarter while in URE, installed the old aux heater on the passenger side for liz and finally got the soft top installed. I'm sure most are wondering why bother with the top now? Well here in fl the summer is when we get the heavy rains. Its our winter. Big thanks to Chuck and Chuzie for getting it fixed up and back to me. :beer: My little mule, Pe'pe - broncosbybart - 04-18-2017 Lookin good! My little mule, Pe'pe - blazinchuck - 04-24-2017 you're welcome Matt, looks good My little mule, Pe'pe - broncomatt - 05-10-2017 After taking my mule to town for dinner and then coming home threw a deep sand power line section, we pulled over for a sudden noise. I restarted it and knew] right away it was a serious problem. Dragged it home with my subie. Tore it down and found a broken crank shaft between 6-7. Luckily it broke clean and since it wasnt run long. No other damage occurred. New crank, all bearings, rings and seals are being replaced. It has been 18 years since I last rebuilt this engine. It was due and I look forward to having it back together again. I'm dropping it off at the machine shop to balance the crank and check the crank in the block. My little mule, Pe'pe - Bronco Biff - 05-10-2017 now that is pretty crazy! Wonder how long it was cracked..... My little mule, Pe'pe - snipes243 - 05-10-2017 Get it fixed man we got places to go haha |
